16" Split Rims Run Flats
02 Nov 2012 22:02 #1 by dandjcr
dandjcr created the topic: 16" Split Rims Run Flats
Forum Home > On the Road > 16" Split Rims Run Flats
Rodman
How about for you guys that are runing the 16" Split rims using the US Military Run Flat Device?
April 22, 2011 at 12:22 PM Flag Quote & Reply
oka 098
Is that the tube or where is the tube ? dont split rims need a tube?
April 22, 2011 at 2:54 PM Flag Quote & Reply
oka 098
oh yeah no tube ,the edge of tyre wedges against inner ,looking and no thinking ,cheers
April 22, 2011 at 3:18 PM Flag Quote & Reply
Rodman
Some split rims have a ruber seal in the center and that seals the two halfs, so you do not need a tube.
April 22, 2011 at 3:51 PM Flag Quote & Reply
Rodman I tried to fit the humvee wheels to the Oka but they have too much offset and foul the body and steering. They are two piece steel rims with beadlock/runflat as per the pic above, problem is they are 16.6" rims and tyres are getting hard to get plus not much choice here in Oz, the only ones available are the 37x12.5x16.5 Nanakangs which have a similar tread pattern to the MT's in the other post in the xml thread.
April 22, 2011 at 4:18 PM
