Post your interesting, useful and/or unique bush mechanics solutions here for others to smile at and maybe learn from.
Wheel nut taper angle?
01 Sep 2016 18:43 #21
by Alister McBride
Alister McBride replied the topic: Wheel nut taper angle?
It's 90 degrees Peter, it's a fairly standard taper although i think OKA made their own, and fyi you can get domed nuts and just taper them in a lathe to 90 if you need, they seem to come out exactly the same dimensions as original OKA nuts (hmmm).
On anti-seize on wheelnut threads - don't do it! I got sick of trying to undo my nuts and tried it, some wheelnuts came loose for the few months afterwards until it dissipated a bit (what did i expect, slap forehead!). As Dave said, a bit of CRC every now and then... I also now mark the nut and wheel with a marker pen to easily see if nuts are staying put.
cheers, alister
cheers, alister
01 Sep 2016 21:41 - 01 Sep 2016 21:44 #22
by Peter_n_Margaret
Peter_n_Margaret replied the topic: Wheel nut taper angle?
Thanks Alister.
These are better than a marker pen, I reckon..... $90 per 100 from "Redcat".
Last Edit: 01 Sep 2016 21:44 by Peter_n_Margaret.
The following user(s) said Thank You: Joseph Baz, TH
