Tools
Like assembling an Ikea futon??
- Lang
Lang
- OKA 138
I have a long storage draw under the camper body and it restricts access to the bolts on one of the tail gate hinges and the gap in the frame work is only about 2 inches,my arm is too big to fit. When I put it on the firs time I used my daughters boyfriends skinny little arm but they live in Darwin now so I had to come up with another arrangement.
- Paul and Sue Crompton
Paul Crompton - OKA 168
That is correct for the top one Paul. It is a modified 200L drum bung. No hose needed inside the drum, just lay it over on its side once connected.Paul and Sue Crompton wrote: Hi Peter, I am guessing they are air fittings and the bung is to go into a fuel container with a hose extended downwards from the bung and low pressure pushed into the drum so the fuel comes out easily. Much easier than siphoning but I could be well off track. Paul.
The bottom one is for a quite different purpose. Look closely.
- ABE
Screw the brass end into a LPG tank and the other end is a fitting for your air hose, connect air hose and air clamp to the tubeless tyre valve open the LPG tank and put some gas in and light. Puts the tyre back on the rim, if you have been driving on sand at very low pressure and run the tyre off the rim, very dangerous idea if you put too much in or you forget to turn the tap off before lighting.
ABE Tony
ABE Tony
Should be enough pressure, noting the risks of using inflammable gas. Not sure how the rubber of the valve would like it but in an emergency...
No intention of lighting the gas when using this "tool" Tony simply to use the gas for emergency inflation. Have never needed to do it.ABE wrote: Seen one of those years ago. Actually saw the aftermath as the person using it, was killed by the explosion of the tyre rim.
ABE Tony
Not withstanding, I have used flammable gas from a pressure pack can to re seat a tyre bead successfully on several occasions.
Most pressure packs will work. I used ether (starting gas) on one occasion. It is surprisingly difficult to get the explosion required.
- Peter334
- Peter334
Call SUPER TOOOOL,
Ok time to put the hinge back on, 4 bolts and nuts, first commandment of work shop, user correct tool, super tool to the rescue.
First two were difficult but eventually got it done.
Number 3 however was not so easy, the first nut went on ok but the lock nut would not start.
Second commandment, thou shall not curse. Third commandment thou shall not throw tools. Fourth commandment thou shall remain calm and patient.
Luckily I am calm and patient , had a good teacher when I was young, actually I had thousands of teachers, SHEEP, I learnt the hard way.
Ok so back to bolt number three, I had spent some 15 minutes trying to get it to start and was back at the bench for the third time to re tape the nut into the ring spanner. While I was there I had more bolts on the bench so I tried the nut on another bolt but it wouldn't start, gave it a few goes then grabbed an new nut out of a box full of them and it went straight on
Call SUPER TOOOOL,
So as I went to chuck the nut in the bin I had a look at the thread, there was no thread
So as I went to chuck the nut in the bin I had a look at the thread, there was no thread, it was smooth, I just laughed out load, what else could I do. It had to happen on one of the hard to get to spots didn't it.
Put the last two bolts in in less than 10 minutes.
