Tools
  • Ewart and Vivian Halford
  • Ewart and Vivian Halford's Avatar Topic Author
  • Offline
06 Dec 2016 20:17 #21 by Ewart and Vivian Halford
Ewart and Vivian Halford replied the topic: Tools
Ok don't know what happened to the end of the story.
So as I went to chuck the nut in the bin I had a look at the thread, there was no thread, it was smooth, I just laughed out load, what else could I do. It had to happen on one of the hard to get to spots didn't it.
Put the last two bolts in in less than 10 minutes.
  • Offline
06 Dec 2016 20:25 #22 by Ewart and Vivian Halford
Sorry about this every one, just figured out what I did wrong, I put a couple of smiley faces in the text and it only sent to the first smiley face.
So on a serious not has any one got a list of unusual tools they take with them such as unusual size sockets, eg 5/16 for uni sadle.
07 Dec 2016 07:17 #23 by outyonda
outyonda replied the topic: Tools
dandjcr wrote: Had a discussion with Peter some time ago about the use of a gas bottle to inflate a tyre if all else has failed.
Should be enough pressure, noting the risks of using inflammable gas. Not sure how the rubber of the valve would like it but in an emergency...
Can of Airostart dose the trick,
Farmers & tyre fitters do it regularly out in the bush
07 Dec 2016 16:59 #24 by OKA 138
OKA 138 replied the topic: Tools
Don't use it often
Dave
07 Dec 2016 17:00 #25 by OKA 138
That didn't work to good
08 Dec 2016 09:52 #26 by Dean and Kaye Howells
Dean and Kaye Howells replied the topic: Tools
A lot easier (and safer) just to carry a spare tube and sort it out properly later.
09 Dec 2016 16:32 #27 by Peter334
Peter334 replied the topic: Tools
HERE,HERE Dean!
10 Dec 2016 03:51 #28 by Peter and Sandra OKA 374
Peter and Sandra OKA 374 replied the topic: Tools
My take on it was using the actual gas pressure to reseat/inflate the tyre if no air compressor was available, trying to light LPG to reseat would be asking for trouble, might be fine with a quick squirt of Aerostart or similar but to try using lpg for that purpose would be a very good way to kill yourself and destroy everything in close proximity.
10 Dec 2016 05:04 #29 by dandjcr
dandjcr replied the topic: Tools
Peter and Sandra OKA 374 wrote: My take on it was using the actual gas pressure to reseat/inflate the tyre if no air compressor was available,
Thanks Peter, that was the point of my pressure measurement. Explosive reseating a tyre is a separate issue.
Carrying a spare tube is fine if you have (or can get) the tools and strength to install one, but you'll still need a source of air pressure.
I guess a foot pump could be used but would take for ever. What I do is keep both spares up to 80+psi and carry a tyre to tyre air pipe to inflate one from another.
Gas is very much a last resort.
10 Dec 2016 08:08 #30 by outyonda
Google
Inflate tyre with ether
10 Dec 2016 09:04 #31 by Peter_n_Margaret
Peter_n_Margaret replied the topic: Tools
Peter and Sandra OKA 374 wrote: My take on it was using the actual gas pressure to reseat/inflate the tyre if no air compressor was available, trying to light LPG to reseat would be asking for trouble, might be fine with a quick squirt of Aerostart or similar but to try using lpg for that purpose would be a very good way to kill yourself and destroy everything in close proximity.
Correct.
Correct..... or even higher. 305s can run at 115psi, so can store at least that safely.
Tyre to air hose connection piece....
12 Dec 2016 21:53 #32 by Joseph Baz
Joseph Baz replied the topic: Tools
Do you really want to try this when you are miles away from help and you can really injure yourself?...sorry not for me
Cheers, Joe
13 Dec 2016 04:55 #33 by Lang
Lang replied the topic: Tools
WD 40 works fine for explosive seating (just a gentle "poof")
My question is why go to the trouble of gas bottles, overfull spares and double ended hoses etc when my 12v air compressor bought at Super Cheap 10 years ago for $19 - I think they are $29 now - has topped up dozens and completely filled about 30 tyres and is still going strong? I carry a foot pump as back-up but have never used it.
Lang
