- The Camp Fire
- On The Road
- 2011 OTR Archives
- December 2011 OTR
- New OKA-Box build for the Lee's 123
01 Nov 2012 19:00 #1
dandjcr created the topic: New OKA-Box build for the Lee's 123
Forum Home > On the Road > New OKA-Box build for the Lee's 123
picasaweb.google.com/1146117281102541343...r0wE&feat=directlink
should take you to an album with a selection of photos showing progress on this build. Most phots have fairly comprehensive captions to fill in a bit of the detail.
I'll add more as the job progresses.
December 22, 2011 at 6:53 AM Flag Quote & Reply
Looks great, you've made great progress, we'll have to call in and have a squiz.
December 22, 2011 at 7:36 AM Flag Quote & Reply
Any time. Won't be going anywhere until the end of January when I'll be taking a break in PNG for a month and then it will be back into it to make sure it is ready for the May trip.
December 22, 2011 at 7:46 AM Flag Quote & Reply
James & Usha (THEByleDuct)
Fantastic to read through the builders log with pics. Inspirational to say the least.
OKA #072
December 22, 2011 at 11:37 AM Flag Quote & Reply
That sure is one big construction and you seem to be tackling it at great pace it should look very good when finished ,you did mentioned the cork floor tiles take a long time to stick ,i have layed them before and if you glue both sides give a couple of minutes to be come tacky then place them on make sure you get it right , i used cork glue for the job, good job keep trucking
December 22, 2011 at 8:14 PM Flag Quote & Reply
Progress slow and steady.
Few more photois added to the Picassa album. See first post for link.
January 9, 2012 at 12:23 AM Flag Quote & Reply
Tony,
Had a look at your build... what can i say but fantastic. your going to end up with a real goodin...
while im at the keyboad...
you mentioned the battery and its your build... have you ever seen batteries explode or gasses escape due to over heating and or nil ventilation? not a good thing.
re your noisy winch. We just purchased a small one for a Suzuki somethingarother ( small 4x4) it was as noisy as yours sounds. thought it was nackered. we pulled it apart and removed all the 'grease' and replaced with propper heat grease. worked a treet. try it might save you going nutty.
cando
Happy trails
Cando and Bron XLT 112
January 13, 2012 at 8:23 PM Flag Quote & Reply
"you mentioned the battery and its your build... have you ever seen batteries explode or gasses escape due to over heating and or nil ventilation? not a good thing."
My first project during my relativelky short stay at the Engineering Research Lab at Lucas Heights involved helping with a rig trying to simulate the heating of liquids inside a reactor by passing heavy currents (3000amps or so) through a SS pipe with water flowing inside. Couldn't get a mains supply big enough so I went to Garden Island to look at a submarine battery - or rather half a submarine battery. We ended up getting a large number of these single cells - standing about 1200mm high and weighing half a tonne each - in fibreglass cases.
Charging regime was strictly according to the navy handbook which I had to copy out longhand because security prevented me getting photocopies Doh!!! - but it was fairly common to come in in the morning after an overnight charge to find one of the cells split wide open with acid all over the place. Luckily they were outside and after the first one blew up, secured behind a high fence.
My AGM batteries have an easier life and the solar regulator has temperature regulation on it as well. No mains connection on board either so I figure a rupture is extremely unlikely and even if the regulator fails-dangerous, the maximum current from the regulator (=C/25) is not going to produce catostophic failure either.
The two AGM batteries are half the compliment out of the BigRig so have already had plenty of practice at being ignored and buried under a heap of stuff in the storage bins so I think they will survive their new job (where there is reasonable ventilation) OK. Me too since I will be sharing the same general air space.
January 13, 2012 at 9:12 PM Flag Quote & Reply
Re the winch. This was an eBay special - $75 for a 3000lb unit.
Guess the noise is to be expected from a unit where the planetary gears are filed out by hand on a sweatshop bench somewhere. I did pull it partly apart and added a little bit of grease, but maybe I should do a proper job and dismantle it completely and use a proper amount of decent grease. It wasn't too high on my list then but pretty soon sheer embarrassment will drive it to the top of the list.
Did try idling the OKA and the winch is considerably less obvious - and I can raise and lower it by hand if absolutely necessary - so if I can't quieten it much, I might try living with it. Camping early and setting out late as we do, I shouldn't ever wake anyone up
January 13, 2012 at 9:20 PM Flag Quote & Reply
Back into it after 5 weeks working holiday in PNG.
Getting there. Kitchen completed and bathroom too so dining area is my next job while neighbour from across the road sews up the canvas for the bedroom
March 13, 2012 at 11:37 PM
OKA #072
Tony,
cando
Happy trails
