Bushes for gear selector control box
- Peter Davis
01 Aug 2014 07:56 #1
by Peter Davis
Peter Davis created the topic: Bushes for gear selector control box
The bushes in my gear selector control box are worn and need changing as I,m getting tired of the rattle. Does any one know where I can buy some or the sizes to get some made? They are part No.23 008727 on the oka parts listing.
05 Aug 2014 18:06 - 05 Aug 2014 18:08 #2
by outyonda
outyonda replied the topic: Bushes for gear selector control box
OKA Parts, Allan has them
0400 736117
0400 736117
Last Edit: 05 Aug 2014 18:08 by outyonda.
- Peter Davis
21 Aug 2014 06:11 #3
by Peter Davis
Peter Davis replied the topic: Bushes for gear selector control box
I purchased the bushes from Allan. However, they weren't the ones I thought to go between the sector, the housing and end cover. Another option does anyone have a gear selector for sale after an auto conversion or can one purchase a new gear selector.
21 Aug 2014 07:03 - 21 Aug 2014 07:04 #4
by outyonda
Peter, do you mean the sleeve that comes out of the rear before the U/J?
you can get the polyurethane sleeve OR, 10 years ago I used 1" high pressure polly pipe. cut a small strip to size & last longer.
there is several posts about the dreaded gear change.
A mm of play at gear box is an inch of slop at gear stick.
check all your rose joints & connections.
Last Edit: 21 Aug 2014 07:04 by outyonda.
- Peter Davis
21 Aug 2014 09:59 #5
by Peter Davis
I forgot to mention it is a LT. I see the XT has a different set up. It selects ok, its more the rattle of the gear stick which I'm trying to fix. Putting a new seal in will probably fix the rattle but there is a fair bit of slop which I assume will flog out the seal fairly quickly. I don't know if there is a sleeve there, the shaft or the end cover need building up. Your suggestion of poly pipe maybe the way to go. I'll have to pull it apart.
