Removal of Orkot bush
14 Oct 2018 14:09 #1 by Peter Davis
Peter Davis created the topic: Removal of Orkot bush
The Orkot bushes can be quite challenging to remove esp in the chassis.
Should they be greased, oiled, lithium greased etc before insertion so there are less expletives in about 10 years time.
14 Oct 2018 20:21 #2 by Holmz
Holmz replied the topic: Removal of Orkot bush
More....
(How do you get it out? Looking replace with nylon bushings...)
Mrs had me flat chat in the garden today, so more like a blur than like a stationary garden gnome.
15 Oct 2018 15:34 #3 by Peter Davis
Peter Davis replied the topic: Removal of Orkot bush
Using a homemade press. The chassis one isn't worn as much as the spring eye bush.
15 Oct 2018 16:52 #4 by mort
mort replied the topic: Removal of Orkot bush
I have done mine and helped with 3 others and its a lottery as to which one is easy or hard to remove.
Most of mine were easy just a few taps and out and Vinces were a bit harder but the third I spent hours with a gimpie and drift to move it about 10 mm in the end I used my recipro saw with a steel blade and cut 2 slots then a good quality screwdriver with a shaft all the way through the handle ( so I could use a hammer on it ) and removed the cut piece, the rest just fell out. you have to be carefull not to cut the chassis mount. The rest on that same oka were just as hard and I used the same method.
The 4th oka was so easy they just fell out.
The new bushes were neoprene with 22 mm pins but if I was using Orkot would greese help I dont know, if it is such a tight fit would the greese be pushed out ..maybe ..and if any left would it still be there in 10 years or would it be dried up or would it allow the sleeve to rotate and then cause wear on the chassis mount.
15 Oct 2018 17:21 #5 by Peter_n_Margaret
Peter_n_Margaret replied the topic: Removal of Orkot bush
Split it with a sabre saw?
16 Oct 2018 19:02 #6 by mort
Hi Peter,
I would think with that ? mark your are asking is it the same tool as a recipro saw, I am sure if I got it wrong you will let me know.
A recipro saw short for reciprocating saw is the same as a sabre or sawzall and a few other names that different manufacturers call them.
The sleeve is not a full piece it has a split so if in the right position it really only needs 1 cut but you have to pay attention that it is an even cut or else you could cut through the chassis mount.
I do know of someone who used a hack saw to cut.
16 Oct 2018 19:36 #7 by Peter_n_Margaret
You got it correct :)
  • Peter and Sandra OKA 374
18 Oct 2018 05:45 #8 by Peter and Sandra OKA 374
Peter and Sandra OKA 374 replied the topic: Removal of Orkot bush
None of mine were tight even after 22 years but then 374 has only just clocked up 188k most under my ownership so well greased!
The replacement brass bushes were easily fitted using an enerpac and a jig to pull them in.
19 Oct 2018 13:36 #9 by fran philipson
fran philipson replied the topic: Removal of Orkot bush
Some of my bushes were easy to get out ,others were frozen solid. the stuck ones I just ran a bead of weld around the inside and they just fell out
19 Oct 2018 15:30 #10 by Holmz
5/8" threaded rod, nuts, and washers... along with a rattle gun also works.
20 Oct 2018 03:44 #11 by Peter and Sandra OKA 374
Yes the 5/8 or 16mm works unlike the 1/2" which stretched.
