Adding photos
- Peter Davis
Do I go to attachments, add file, find the file and open it, it then appears in the attachment box. I click insert file it is added next to the text. I click submit, the computer vegetates for a few minutes and then comes up internal server error.
Am I doing something wrong?
- Peter Davis
The files are jpg. I've tried reducing there size as well, but no luck.
- Cando
XLT-112
If you have any other problems uploading or attaching documents, please let me know, they can probably be resolved.
This is a png pic (Ducks1.png). "Ducks 1.png" with a space didn't always work.
Peter Davis wrote: Is there a trick to adding photos onto for sale item?
Peter, that's the correct procedure but sometimes spaces or other non alpha-numeric characters in file names can cause problems. Try removing or replacing them before uploading. jpg, jpeg, gif and png formats are acceptable for image attachments.
Also keep the image file size as small as reasonable, and below 3mb, they'll upload quicker and be resized to fit anyway. (File attachments, eg non-images such as pdf's, can be larger).
Cando wrote: id like to upload from an ipod or iphone ut still unable to. will this still change wen the old site is turned off?
Cando, I don't have either of these devices to try, (did you mean iPad?)
Can anyone else throw some light on this problem?
Thank you.
I will take a photo now and see what happens.
First pic taken then attached,
Second pic from existing pics
Cat
Oka
Ok then it appear that the iPad must be the right way up, my I pad 3 with a protective cover on must have inverted the ipad 3, were the cover on my iPad cellular and wireless has the iPad the correct upright position.
- Peter Davis
seems to have done the trick.
- Cando
XLT-112
- Cando
- Peter Davis
- Peter Davis
- Cando
