Heater Fan
01 Nov 2012 12:10 #1
dandjcr created the topic: Heater Fan
Forum Home > OKA Maintenance > Heater Fan
I am trying to locate a heater fan for my XT as it has developed a squeal on start up and rattles, Any one know where to get them from, not sure if I need the Drum fan as part of the Assembly, but likely
Many thanks David
July 20, 2010 at 7:49 AM Flag Quote & Reply
I replaced mine in October '06 while I was in Kalgoorlie.
Robin Wade sourced the replacement motor locally in Kalgoorlie. It is a common style and easily identified (once removed). Cost $170 at the time.
July 20, 2010 at 9:14 AM Flag Quote & Reply
Rod Lyons
G,day David, I replaced ours with a EM 2464 from Cooldrive for about $130.00 I think you need to change mounting holes. If your not near a major city I can post one to you, for the same cost including postage.
Cheers Rod
July 20, 2010 at 10:50 AM Flag Quote & Reply
Rod Lyons
Sorry David that part is EM2465 & it will cost $190.00 inc postage, the other one is to small.
July 20, 2010 at 11:06 AM
Many thanks David
Rod Lyons
Cheers Rod
Rod Lyons
