Baby capsule fitting
30 Oct 2012 16:18 #1 by dandjcr
dandjcr created the topic: Baby capsule fitting
Forum Home > OKA Maintenance > Baby capsule fitting
Has anyone fitted a baby capsule on the engine hatch or know anyone who has had it done?
Be good to find an engineer in Brisbane who could certify one.
March 31, 2011 at 10:52 AM Flag Quote & Reply
I have seen a Child Seat fitted on the engine cover, Robin Wade have the vehicle there a few years back, Had the seat belts and Child bolt fitted to make it legal, Believe it had a compliance to suit
April 1, 2011 at 7:53 AM Flag Quote & Reply
Peter, I did this ten years ago but never took any photos. Well not exactly me; I gave the Oka to a company that specialises in building rally cars, Maximum Motorsport, for the sole purpose of fitting a baby capsule to the engine hatch, and they had no hesitation about it all. It was done to specifically suit the capsule we had, not a generic fit.
The most obvious modification was a vertical bar fitted at the back of the cab, or more correctly at the front of the bus body. It was bolted in top and bottom into nuts welded into the frames, not unlike seatbelt mounting points. The bar carried the clip that the forward straps attached to, above the capsule.
There were locating bumpers fitted to the engine cover at three or four points, and the capsule went over them and was held down by an additional seatbelt strap - but I can't remember how that was done. Anyway Maximum Motorsport are obviously in the business of keeping seats and people in situ in much more spectacular incidents than most Okas will ever see, so I was completely confident that what they did would be as good as you could get. They're the kind of people I would be seeking out to get the job done in Brisbane too.
April 2, 2011 at 4:06 PM Flag Quote & Reply
Thanks a heap for that Hal......
I suspect there is no technical problem and we are just argueing about the money....
April 2, 2011 at 10:17 PM Flag Quote & Reply
Just a note to say that OKA196 has a mounting system for a baby capsule (Cat 2, max seated height of child 760mm from memory) on the engine cover.
Quite simple actually.
It has been approved by an engineer in Brisbane.
With some luck, I will be able to post some pics and a description at a later date and also the name of the engineer (if he wants that to happen).
The 2 seats at the rear of the camper section (that I had engineered, but not sought approval for when I built the body) are now also approved.
So, we are a 5 seater.
September 11, 2011 at 1:07 PM Flag Quote & Reply
>> So, we are a 5 seater. <<
The new series - Four and a Half Men!
September 11, 2011 at 1:24 PM Flag Quote & Reply
old post,
Any one got pictures or know where I could order one?
I am in the middle of the NT, so little hard to get engineer to build one here.
July 14, 2012 at 10:13 AM Flag Quote & Reply
It is not something you "buy". It has to be built.
Not too complicated though but will need an engineer to approve it.
OKA196 is having some work done on it at the mo, but when it is back I will get some pics and post them.
July 14, 2012 at 10:53 AM Flag Quote & Reply
Hi Pete,
Yes understand. I was more thinking of a little dicky sit or child seat. Not sure.
Is the OKA at St Mary`s?
July 14, 2012 at 12:40 PM Flag Quote & Reply
Yes. It is at Saint Marys Auto.
The child seat is not in it at the mo, but all 'mods' for mounting it are all there.
I will be picking it up from there on Monday sometime or you could call into home at some time later to have a look.
....But I thought you were in NT?
July 14, 2012 at 5:28 PM Flag Quote & Reply
Factory OKA Rear Seats are fitted with a Child mounting point in the seat, for the fitting of Baby Capsules and Child Seats
OKA-131 Home Page
OKA Camper Trailer
July 16, 2012 at 9:14 AM Flag Quote & Reply
Thanks Peter, I am in the NT. Just I have used the guys at St Mary`s before with your recommendation. Top guys and went way beyond what they had to. Working back late etc etc. At the end of the bill was quite reasonable as well.
David,
Thanks for the info, is this all seats are just a few??
July 16, 2012 at 9:54 AM Flag Quote & Reply
Should be all OKA rear seats. there will be a hole with brass ring, just fit a standard floor / Roof child restraining mount and bolt in.
OKA-131 Home Page
OKA Camper Trailer
July 16, 2012 at 11:03 AM Flag Quote & Reply
From memory (last job before retirement) any small (less than 15 seat) busses/people carriers/vans etc registered in NSW since about 2000 must have baby seat mounts fitted to the rearmost seats in the two outboard seating postions. Depending on the seats themselves the mounts can be fitted to the seats, frames or the floor behind them, depends on the engineer involved.
July 16, 2012 at 11:38 AM
