Solar panel support
01 Nov 2012 13:40 #1 by dandjcr
dandjcr created the topic: Solar panel support
Forum Home > On the Road > Solar panel support
From Tony Lee:
Going to fit a couple of 180W 24V panels, one on the front cabin roof and one on the crewcab. Each panel covers most of its roof and support around the perimeter is no problem, but I wonder if anyone has felt the need for some sort of support in the middle of the panel.
Was thinking of say three small blocks of closed-cell foam just thick enough to push the centre of the panel up a couple of mm. This would eliminate bounce and reduce any tendency for the panel to sag permanently in the middle.
Any thoughts?
May 20, 2010 at 11:51 PM Flag Quote & Reply
From Paul Scherek:
It may be worth considering fitting a number of smaller panels rather than two large panels. Apart from the extra strength of the smaller panels, there is the benefit that in partial shade you can still get useable electricity.
Similarly, if one panel is damaged (maybe flying rocks from on-coming vehicles) you lose a smaller percentage of your power - and cost of re-instatement is less!
Of course if money is no object, the Uni-Solar flexible panels weigh practically nothing, are a doddle to mount, and add very little to your height.
May 20, 2010 at 11:52 PM Flag Quote & Reply
From Peter_n_Margaret:
I reckon they will be fine Tony.
They are tougher than they look.
I have three @ 80W and three @ 120W rafted up as a single panel, hinged along one long side, supported in two strips down the middle of the length and attached on one long side.
In '07 I smashed one when I backed into a tree (first time in 15 years that I have damaged a panel). It pushed one end in by 50mm and shattered the glass. It still works JUST THE SAME.
I would consider the self adhesive Unisolars next time for weight reasons, but they are only making the long skinny ones now. I have heard of people removing the frames from ridgid Unisolars and making them flexable though. They are an a S/S sheet and you have to relocate the terminal box. Just say byby to the warranty.
24V panels? Why 24V? Most are 17 - 20V for 12V systems. Are you using an MPPT charger?
May 20, 2010 at 11:54 PM Flag Quote & Reply
From Tony Lee:
My original thinking was since I already have a bigrig with 600W of 24V panels and 4 x 250Ah batteries AND we can't really use both at once, why not make a couple of the panels easily removable, relocate them to the OKA and do the same with two of the batteries and hook them in parallel instead of series, add a MPPT controller and save over $3000.
Then I got lazy/realistic and decided that removing 85kg batteries from the bowels of the bus and clambering over the roof were jobs best left to young men with good backs - so have bought panels and will buy batteries. However, I decided the MPPT was still the way to go because it should provide more power early or late in the day when the output of a 12V panel drops lower than the battery voltage. Having 24V panels gives the controller more margin to work with.
May 20, 2010 at 11:55 PM Flag Quote & Reply
From David Ribbans:
Solar panels are built tough, but a 180 w Sharp (for example) is 1318 x 994 which is a big area of glass. They will be subject to vibration in the vertical plane when mounted flat above the Oka roof and would benefit from any damping you can provide for them.
I would put two or three 25mm square aluminium tubes (or similar) across underneath the panels about 300mm apart with closed cell foam pads to firmly support (but not push up) the glass. This will raise their natural frequency of vibration so they don't resonate at "corrugation frequencies". Mount the tubes longitudinally so they don't reduce air flow.
Might never be needed but judging by how much things vibrate on corrugated tracks it can't do any harm.
Regards,
May 20, 2010 at 11:57 PM Flag Quote & Reply
OKA in Africa
I am planning to upgrade the power system with a photovoltaic solar panel which I'd like to mount on the roof area above the front seats.
I have currently the standard OKA dual battery system installed and no experience with solar panels.
Since I am sometimes travelling through thick bush I am worried that I would smash the glass on the panels. I am considering using a flexible solar system which I could even remove quickly once parked below a tree while camping. Something like www.flexopower.com/Namib-83_4x4_kits.htm would be interesting but the sice does not fit.
I am interested to learn what setups other OKA owners have, i.e. panel sizes and wattage, regulators and how the systems are connected to the vehicle power grid. If you have some pictures of your setup please share them with me.
Thanks for your help and creative input!
OKA 327 in Africa
photo album
September 29, 2012 at 8:20 PM Flag Quote & Reply
600W of PV panels, Plasmatronics PL60 controller, 460Ahr of Fullriver AGM house batteries, 1300W PSW inverter.
Optional connection to the alternator and crank system via a 2 way 200A voltage sensitive relay.
Crank connection and inverter are fed via shunts that report power back to the PL60.
September 29, 2012 at 9:47 PM Flag Quote & Reply
Africa, you might be interested in our solar installation here.
Solar panels are tougher than you might think. After several years of intense bush travel, branches are not the real danger, the only panel we have broken was by a rock thrown up by another vehicle (same as windscreen damage), and it still works fine anyway.
Vibration or thick bush are more likely to damage the mounting frames and wiring than the glass.
Being an electronics engineer I designed my own charge control system but there are plenty of charge controllers available and websites on the subject. MPPT controllers are all the rage but frankly I don't think they deserve the hype.
Parking the Oka in the right place for the sun to be most effective is more important, and the best you'll get from a solar panel is around 75% of the quoted rating anyway due to variations in radiation levels and angles of incidence.
September 29, 2012 at 10:15 PM
28 Feb 2013 02:49 - 28 Feb 2013 05:38 #2 by OKA in Africa
OKA in Africa replied the topic: Solar panel support
Hello,
I did not buy and install my solar panel system yet. My requirements are still the same as in my earlier post.
Since I am away from my OKA sometimes for several months I'd like to keep both batteries charged. I assume that it is not a good idea to connect both batteries parallel to the solar panel while away since the two batteries are of different type. Any idea for a good wiring to keep both batteries healthy? Do you recommend to charge one of the two batteries via a DC to DC charger like the CTEK brand? In this case I probably would have to disconnect the house battery from the existing OKA wiring via the relay?
I did look on the website and did only find one more topic related to solar panels: www.oka4wd.com/on-the-road/721-solar-pan...house-batteries#1432
I assume that the link in the earlier post to the solar installation of "David and Janet Ribbans, Oka 148" got lost with the move to the new website. Could you please post the link again?
Thank you and best regards
OKA #327 in Africa
Last Edit: 28 Feb 2013 05:38 by OKA in Africa.
28 Feb 2013 06:53 #3 by Peter and Sandra OKA 374
Peter and Sandra OKA 374 replied the topic: Solar panel support
OIA
Ideally you need an MPPT solar regulator connected to the largest battery and then a DC to DC charger to charge the second battery from the first/largest one.
It might possibly be cheaper to replace one of the batteries so you have two the same in parallel and then charge off the solar through the regulator. No need for the DC to DC charger then.
Never leave the solar connected to the battery without a regulator or closely monitoring voltages as you will damage the battery.
We run 500w of solar through a Plasmatronics regulator into 4x120aH AGM batteries for the house system in the Oka.
The Oka then has the standard main and auxilary batteries, the auxilary is charged via a Redarc VSR from the main battery.
28 Feb 2013 06:54 - 28 Feb 2013 07:09 #4 by dandjcr
dandjcr replied the topic: Solar panel support
OiA, yes the link to my Solar Panels article got lost in the transfer. The original link is here , but I've also converted it to a pdf document and uploaded it to the new website Technical Documents Library here (4.3mb).
Note that technology (eg solar regulators) and the availability of parts (panel shapes and sizes) has moved on in the 4 years since I built our system so some adaption would be required but the principles remain the same.
Regarding batteries of different types, as long as the batteries are the same technology (eg all lead acid, AGM or Gel) then paralleling them should not be a problem. Solar charging is generally less aggressive than an alternator could supply so there is less risk of damage, but a good regulator is essential anyway.
A CTEK dc-dc charger is not required for a solar installation since the solar panels already generate a charging voltage higher than the batteries need (hence the need for a regulator). A CTEK charger is beneficial in the absence of solar to boost the output from an alternator (which are pre-regulated down to 13.8v) for faster and more effective charging (the alternative is a smart alternator regulator), and obviously is only relevant when the engine is running.
One note about solar panels. Don't ever disconnect the batteries from the solar charger while they are charging. Unregulated solar panels can produce 20-30v which can damage any electronic equipment. The solar regulator might prevent this but why take the chance. An unregulated alternator could do the same damage but it's fairly obvious when an alternator is running whereas it's easy to overlook solar panels.
For the record, our Oka is laid up (outside) for several months over summer and the solar panels keep all three batteries fully charged without attention.
Last Edit: 28 Feb 2013 07:09 by dandjcr.
28 Feb 2013 07:50 #5 by Tony Lee
Tony Lee replied the topic: Solar panel support
OIA - there is a device called trik-l-start - available from the USA - that is a 5 amp charger designed to keep the starter batteries topped up from the house batteries whenever the house batteries are themselves being charged from the solar. Cost about $45 plus postage.
Another option is something like Sunsaver duo solar regulator (that one is probably obsolete) which can handle more than one battery
28 Feb 2013 09:21 - 28 Feb 2013 09:28 #6 by Hank Onthewater
Hank Onthewater replied the topic: Solar panel support
OiA, it is all good and well to spend money on electronics to keep batteries charged up while the vehicle is stationary and unattended for several months, but good quality AGM batteries have a capacity loss of approx 1% per month (I have been told, but can not verify). Maybe that could be a first step. No need to install anything at all!
'Normal' lead acid batteries lose 5-20% of their capacity per month (depending what literature you believe). For reasons outside my control I had 2 AGM batteries sitting unused for 1 year. Terminal voltage was still 12.6 Volt, and each battery started the OKA first go! BTW the manufacturer states a shelf-life of 2 years.
If you were to install solarpanels at a later date, yes, as David said, they will keep your batteries 100% when using a solar regulator/controller. This is commonly connected to the auxilary battery (-ies).
And as you indicated, to charge all batteries, maybe connect the starter battery parallel then. Although if a fault would develop (which is unlikely), this could see you without power at all. Hehe, but likely you would not be in the bush then, and in the civilised world.
In regards to support of the large solarpanels: have you considered flexible solar panels? No need for any support, just stick them to the roof, they are only 1.5 to 5 mm thick. Less wind resistance, no vibration other than that of the roof itself, less likely to be damaged, some can be walked on! There is quite a range of suppliers and manufacturers.
Last Edit: 28 Feb 2013 09:28 by Hank Onthewater.
28 Feb 2013 11:55 - 28 Feb 2013 11:56 #7 by dandjcr
Hank, you are quite right about variable self-discharge rates (I reckon the variation is 1% to 50% per month, depending on their age and condition), but unless the batteries are totally isolated from all other electrical devices, there will also be a small but measurable current drain anyway, due to things such as radios on standby, solar regulators (when there's no solar energy), remote controls, clocks, inverters on standby, alarm systems or even good old leakage through the wiring.
Batteries would prefer being at least float/trickle charged while on the shelf so I think it makes sense to have a standby charging system, then you have no worries on either count.
Last Edit: 28 Feb 2013 11:56 by dandjcr.
07 Mar 2013 08:36 - 07 Mar 2013 08:40 #8 by OKA in Africa
So, I got the CTEK D250S DUAL for a good deal here in the US!
- I currently have a pretty small starter/alternator battery installed in the OKA which supplies plenty of power to the starter motor.
- My auxiliary/service battery is a deep cycle 130Amp type.
- I am planning to cover the roof area above the two front seats (not the cabin area since I have a roof hatch installed) with solar panels.
I hope that the CTEK can do a couple of things:
  1. Operating as a MPPT regulator for the new solar panel(s).
  2. Charging the starter/alternator battery and auxiliary/service battery independently exactly to the requirements of each individual battery during the engine running via the alternator and solar panel(s).
  3. Charging the starter/alternator battery and auxiliary/service battery independently exactly to the requirements of each individual battery during the engine is NOT running via the solar panel(s).
I have attached a sketch below how I do intend to include the CTEK into the existing OKA wiring. I think I will have to disconnect the charge relay otherwise the set up will only work while the alternator is not running (and the charge relay is open). According to the CTEK manual the charger has a "Built in battery guard for the starter battery".
But maybe it is wise to leave the override key switch in place so that I am still able to parallel the two batteries in the event I would need additional power for starting the engine?
I am worried that the CTEK unit might get damaged when the contacts "alternator battery +" and "service battery +" are connected via the override key switch?
I would appreciate your comments and ideas about the set up and wiring described.
OKA #327 in Africa
Last Edit: 07 Mar 2013 08:40 by OKA in Africa.
07 Mar 2013 13:38 - 07 Mar 2013 13:48 #9 by dandjcr
OiA, I've had a look at the CTEK 250s Dual specs and wiring and my understanding is that it take its input from either:
• the starter battery (ie when being charged from the alternator). It then bumps up the voltage to charge the auxiliary battery(ies) (CTEK call them service batteries), or
• from the solar panels to charge the auxiliary battery, but only float charges the starter battery (this sounds wrong but if the starter battery is used only for starting the engine and is being charged by the alternator, then it shouldn't need further charging), or
• both alternator and solar, depending on the state of charge of the batteries.
In both cases it uses an MPPT 5 stage charger.
However if the auxiliary battery becomes fully charged the solar panels will then charge the starter battery if needed.
The maximum output of the CTEK unit is 20A, which includes the auxiliary battery charge current and the load it is supplying, otherwise you'll be running down the battery.
From all this I deduce 4 things:
• The CTEK charger won't do anything to improve the alternator performance and relies entirely on the alternator capacity and regulator settings (you would need a smart regulator, which could interfere with the CTEK operation, and/or larger alternator to improve charging capability).
• You won't need the charge relay in the circuit, the CTEK unit has that functionality built in. It could be left in place, but disconnected, in case of failure.
• The override key switch should be left in place since batteries can fail and you might need it. The CTEK unit does not have a manual paralleling capability (and it would need very heavy wiring if it did). This won't harm the CTEK unit since all you are doing are putting the 2 batteries in parallel so the CTEK unit simply sees 2 batteries with the same terminal voltage and would probably do nothing.
• If you have more than one auxiliary battery, you'd need some diode separation or a voltage sensing relay between them so they can charge in parallel but don't discharge each other overnight. The maximum recommended auxiliary battery capacity is 300AH.
BTW, don't use 24v solar panels, the CTEK input is limited to 22v which the maximum that most 12 v panels would supply.
Smartpass doesn't seem worth the extra money and is only beneficial if you have a large solar array (more than 20A capacity or around 280W) or need to regularly draw more than 20A from your auxiliary battery. It could be added later.
You can of course connect "accessories" to the starter battery but they should be low current or emergency type equipment (eg we connect our HF radio to the starter battery so it always has power when needed, just like the starter motor).
Here is a wiring diagram for a typical alternator/solar installation. It doesn't show the alternator connected to the starter battery:
There some useful websites on the CTEK 250S Dual installation but also a lot of misinformation. Reasonable ones seem to be:
Kampers.com
jtsonlin.com
carvans and motorhomes
go see australia (Pretty girl too)
Last Edit: 07 Mar 2013 13:48 by dandjcr.
08 Mar 2013 02:08 - 08 Mar 2013 02:13 #10 by OKA in Africa
Dear David,
thanks for that elaborated feedback which really helps!
Another question somebody might help me with, the size of the solar panels I have to buy. To cover the roof above the two front seats with panel(s) will supply me with sufficient power for my needs.
Since I am not at the vehicle to take measurements I wanted to find out if somebody could supply me with measurements of the surface as indicated in red in the sketch below?
Depending on the dimension of available panels I would probably need to install two or more panels to make maximum use of the surface.
I considered to install the panel(s) with special plastic brackets (picture below) which I could glue to the roof with Sikaflex. I then did remember that the surface is not flat, is that correct? I probably have to make a bracket and fix it to the roof rack and/or sun visor mounting bolts?
I would like to then be able to easily remove the panels from a bracket to move them into the sun while camping. Maybe the type of clips used to fix the dasboard into position would be appropriate?
OKA #327 in Africa
Last Edit: 08 Mar 2013 02:13 by OKA in Africa.
08 Mar 2013 04:48 - 08 Mar 2013 05:22 #11 by Peter and Sandra OKA 374
OIA you should not mount them flat on any surface as they get too hot which lead to lower outputs. As you said too the roof is no where near flat enough. They need to be mounted so that there is airflow between the panels and the roof, I mounted two 125W panels side by side on the original roof bars which mount to the captive nuts in the sides of the turret. The just about cover the entire cabin roof and out over the back edge of the visor.
I bought them from Bit_Deals on ebay. They are 1100 x 808mm and about 35mm thick, weigh 11.2kgs each.
I would not bother with making them removeable, too high up to easily remove from the roof, they make a good tropical roof and keep the cab cooler. Panels are getting cheaper all the time, those particular panels are the same ones I bought two years ago, they are now half the price.
Last Edit: 08 Mar 2013 05:22 by Peter and Sandra OKA 374. Reason: link didn't work
08 Mar 2013 05:25 - 08 Mar 2013 05:29 #12 by Peter and Sandra OKA 374
Here is the link to the ebay seller. 125w panel
They are good to deal with, lots of people on 4wd and motorhome forums have bought panels from them without any hassle.
Last Edit: 08 Mar 2013 05:29 by Peter and Sandra OKA 374.
08 Mar 2013 06:35 #13 by dandjcr
OiA, agree with Peter, I would permanently mount them following the cabin roof line about 50mm above. I think 200-300W is plenty but it does depend on your electrical power needs and battery capacity.
The cabin roof appears to be only around 1m deep so you'll need to choose the panels carefully, they all vary in size (125w and 95w are 1100 or 1200mm long), but some overhang might be acceptable.
You could also consider more, lower power panels (eg 3 x 95w panels rather than 2 x 125W) since they would be stronger, easier to mount, with more redundancy and resistance to shading.
If you have a Jaycar or equivalent store in SA, they would have have plenty of mounting bracket options. I would recommend full length longitudinal mounting bars to reduce the effects of shock and vibration. I used lengths of angle ali and made some simple Z brackets to attach to the roof (sealed to stop ingress of water). Air flow under the panels is important for cooling.
If you need a removable panel, you could add one or 2 smaller, easier to store, 40w panels and lay them in the sun.
08 Mar 2013 09:12 - 08 Mar 2013 09:17 #14 by Len208
Len208 replied the topic: Solar panel support
Hi,
Some of this stuff seems overly complicated.we have been on the road for 2.5 years with the system.It consists of an 80amp alternator which charges 520amps of house batteries thru a 100 amp redarc relay,The relay does allow an overide button so that in the event of failure with vehicle batteries you can use house to start.The relay doesnt cut in until the vehicle batteries are above 12.6 volts.In addition I have 520watts of solar charging thru a plasmatronic 40 regulator.We sit for extended periods at bush camps,but have had to use the generator a minimal number of times.This usually when the weather is extremely hot but it very cloudy.We run an electric upright waeco fridge and a waeco freezer,computers, sat. tv.and other devices as you would at home.The only addition we will get round to is a free standing 200watt panel for shaded locations,which will get a lot of use when we go back east.The solar panels are wired back to the regulator separately,so that should a panel fail we still have some power.
Last Edit: 08 Mar 2013 09:17 by Len208.
08 Mar 2013 10:33 #15 by Peter and Sandra OKA 374
We run four 125w panels charging 480ah of batteries, we don't charge the batteries from the vehicle at all and in over 2 years they have never fallen below 60% capacity. We use a 1000w 240v electric jug, normal Sunbeam toaster and a single inductive cooktop occasionally through the inverter. All LED lighting is 12v as is the 130l fridge, cooking is done on a diesel cooktop and diesel supplies hot water and central heating. We have no gas. Occasionally when there is an excess of solar we have switched the 240 element on in the HWS instead of using diesel.
We also have all the usual stuff that needs charging like laptops, printer, kindles, phones, broadband modem etc etc. On the very rare occasions we want TV we use a dongle in one of the laptops but do occasionally watch DVD's or movies on the laptop.
08 Mar 2013 10:46 - 08 Mar 2013 10:50 #16 by Tony Lee
I was a bit concerned at the lack of rigidity of the panels for mounting flat in an application that was going to cop sustained severe hammering from driving over corrugations, so I used several pieces of 'noodle' as supporting columns - cut to slightly more than the distance between the underside of the panel and the roof. This dampens the movement of the panel plus slightly domes the panel instead of its normal saucer shape so water doesn't collect.
We have 2 x 180W (I think) and there were times when stationary for a few days when it couldn't quite keep up with all the junk we run, so I'll be adding an extra panel now the price has come down so much.
Last Edit: 08 Mar 2013 10:50 by Tony Lee.
10 Mar 2013 14:42 #17 by OKA in Africa
Thanks for your feedback!
I am not able to take measurements on my OKA now. Anybody there who could help me with measurements of the surface as indicated in red in the sketch above?
Thanks so much ...
OKA #327 in Africa
10 Mar 2013 14:52 #18 by James and Usha
James and Usha replied the topic: Solar panel support
OiA - on my XT the width is 1720 and the length is 1130 for your red markings.
#072
10 Mar 2013 14:54 - 10 Mar 2013 14:55 #19 by PeteFox
PeteFox replied the topic: Solar panel support
1120 deep x 1730 wide on LT 266
Last Edit: 10 Mar 2013 14:55 by PeteFox.
10 Mar 2013 23:00 #20 by OKA in Africa
Thanks a lot for the measurements of the roof area!
Tony Lee,
looking at your set up on picasaweb.google.com/1146117281102541343...#5600904487100886354 I was wondering if you have a close up pictures of your bracket and fitting of the front solar panel? Looks like your panel is close to to roof but still has enough air flow between roof and panel.
OKA #327 in Africa
