Reviewing a post
  • Ewart and Vivian Halford
  • Ewart and Vivian Halford's Avatar Topic Author
  • Offline
19 Aug 2017 18:41 #1 by Ewart and Vivian Halford
Ewart and Vivian Halford created the topic: Reviewing a post
Hi I have just put up a post, it must be my first major post since upgrade.
I am using my iPad and as I was looking back at what I had typed some lines were off the screen and I could not access them, I then went to review it but it was the same.
I sent the post and when I looked at that I noticed some typos that I could not see to correct.
Mmmm I don't seem to have the same issue now even if I try to make the letters go off the page they won't.
20 Aug 2017 06:55 - 20 Aug 2017 07:07 #2 by dandjcr
dandjcr replied the topic: Reviewing a post
Ewart, you're not alone, it happens to me sometimes (Mac/Safari, maybe an Apple thing, I don't have a pc to test it), especially when posting a long sentence or an awkward sized photo (like the test files below).
It looks like a window sizing issue and I'll see if there any settings to change that.
Sometimes you'll just have to hit Submit and hope for the best (like now), then edit the post if you find errors.
You'll also notice that this version works slightly differently to the previous one. When you add an attachment it uploads the file/photo immediately, so you have to wait until that's complete before you can hit the "Insert" button. A bit annoying for large photos. I'll check that out too.
Regards, David
Turbo upgrade: Gearshafts before and after modification:
File Attachment:
File Name: ToyoM608Z2...heet.pdf
File Size:334 KB
Last Edit: 20 Aug 2017 07:07 by dandjcr.
21 Aug 2017 06:44 #3 by dandjcr
Ewart, I can't find any admin settings which affect either of these issues so they must be set in the background code.
I'll need to raise it to a higher authority to check further.
  • Offline
23 Aug 2017 18:14 #4 by Ewart and Vivian Halford
Ewart and Vivian Halford replied the topic: Reviewing a post
Thanks David, it has only happened once so I am not to fussed but I thought you and James might like to know.
Thank you for all your efforts.
