Part Numbers
01 Nov 2012 11:27 #1
dandjcr created the topic: Part Numbers
Forum Home > OKA Maintenance > Part Numbers
Can someone please provide me with VDO part numbers for the following.
Oil Pressure Sender
Temperature Sender
and also part number for the NP205 Front output seal
November 11, 2010 at 10:30 PM Flag Quote & Reply
Transfer box front seal.
My box says Chicago Rawhide N410308 and CR21213, however Paul Nott will know the correct number.
Check out the wiring before replacing the temp/oil senders, it very likely a broken wire or faulty connection. The meters seem very sensitive to resistance variations in the wiring.
November 12, 2010 at 10:55 AM
Oil Pressure Sender
Temperature Sender
08 Jan 2013 19:31 #2
by Outback Jack
Outback Jack replied the topic: Part Numbers
Any one have the Oil Pressure sender and Temp Sender VDO part number??? Put new oil in and now pressure is even lower.
Even if it turns out just to be wiring, for the sake of 30 or 40 dollars, would rather replace it.
08 Jan 2013 19:45 - 08 Jan 2013 19:46 #3
dandjcr replied the topic: Part Numbers
Last Edit: 08 Jan 2013 19:46 by dandjcr.
08 Jan 2013 19:46 #4
by Outback Jack
Thanks David, I will give them a call to get part numbers if no one can provide the numbers
08 Jan 2013 19:56 #5
Useful
VDO installation guides
are here.
BTW, whenever I see or find a useful technical document, I'll put a copy in the Technical Documents library.
Takes a day or 2 for things to filter though but always worth looking in there for tech docs and catalogs.
