Turbo upgrade
- OKA 138
Fuel temperature also plays a big part so keep that below 60c, I would say its unlikely our Oka / Perkins would have a problem of that nature but a fuel cooler is quite easy to make and fit if required.
EGT's max out at 650 odd at about 100mm past the turbo if you make it lug too much, typical cruising temps are anywhere from mid 400's to mid 500's. On a recent long climb up Thunderbolts north of Gloucester on a high 30's day ad high humidity of 1st and 2nd gear for 11 k's it sat at around low 600's for most of the climb, I ended up turning the A/C off as the red temp warning light came on for the engine and the gauge kept getting up to the edge of the red as the fan cycled. Once the A/C was off it handled it easily engine temp wise.
The auto coolers are mounted in the front bashplate so while they would have put heat under the engine it wouldn't have effected it. Tranny temps cycled between 90 and 110 during the climb again as the cooling fans cut in and out.
I've done absolutely nothing to the engine so either the RAAF fiddled with it or it was that way from new. 374 has now clocked up around 140,000 kms, 70 in our ownership.
worn or dirty injectors
partially blocker fuel filter
worn/maladjust accelerator cable
air filter dirty
exhaust blocked/restricted
is there a considerable difference in weight between vehicles
difference in tuning
all are valid reasons for difference in power and or speed
Things I have done and all have given noticeable increase in power or performance
replaced baffled muffler with a free flow
replaced air filter with larger
replaced 70mm snorkle with 100mm
replaced air intake cowl with larger
matched ported intake and exhaust manifold
installed large intercooler
replaced water pump with electric
replaced fan with electric
I am working on the turbo
when turbo fitted will retune and have the injector pump pressure increased to 12 from 9
I hope this helps if you need more info just ring always happy to talk just dont like typing
- oztrax
Are you referring to adjusting the max fuel screw ?
As per my other reply on "bolt on horsepower" other adjustments can be made to the boost compensator part of the VE fuel pump,
My research has shown EGTs should be kept below 600 degrees C, certainly for a sustained time.
Another option is to squirt water into inter cooler matrix with an old windshield washer pump and small garden spray jet, this will drop EGTs dramatically each time you spray water in,
Boost around 14 psi is what we aimed for on TDI 300 tuning, mine was 16 psi max, up from 10 or 11 psi was amazing performance increase.
Also remember Perkins turbo doesn't have a waste gate, this gives more boost ,power increase to lower/midrange than top end.
I believe that is why the Perkins has good low end torque. The top end boost peters out, and feels like the engine has run out of steam,
A compromise can be found on waste gate turbos by adjusting springs etc,
Regards OZ
I will assume you are referring to my post if not I was expecting someone to ask so...
the factory setting for the pressure the fuel is delivered at is set at 9 which is ok but increasing the pressure not the amount has a result of a finer spray which means better mixture of fuel/air and a better detonation resulting in more efficient fuel economy and more power its a setting a lot of people dont consider.
- oztrax
Exactly where is the adjustment you speak of ?
On the side of injector pump ?
Oz
Personally I dont know a mate is going to do the adjustments as he is experienced thats why I have lots of people to call on so I dont have to do it ( I hope they dont read this ) but I did ask and it is in the front. After the turbo is done he will come over and set it up so I can find out exactly then
- catdav
Would be very interesting to know how this works to my understanding when you rebuild injectors you set them to crack at a certain pressure if you change the pressure delivered to the injectors without altering injectors I thought you would only alter the duration of injection could be good or bad depending on variables I could be wrong here though interesting
You are right CatDav,mechanical injectors are built and rebuilt exactly like that.
It looks a good unit and all the work that went into it I am confident the performance will be what I am after, One figure the engineers sent is a compression ratio of original is 1.7 at 1100 rpm new 2 at 1100 rpm anyway I am away for 2 wks so not long now.
well I am back didnt find enough Gold to allow me to retire but had fun
Latest Turbo fitted and Today went to get Dyno and injector pump adjusted so the result is
before Klm /hour 90 kilowatts 48 rpm 2500 boost 10 EGT 400
after Klm /hour 90 kilowatts 64 rpm 2500 boost 16 EGT 450
Not engine output but at the wheels
No intercooler installed as I wanted as close to std
So my honest impression if the OKA performed like it does now when I got it I would have been thinking what is every one complaining about it is fast in all gears and in fact I was thinking on the way home I have to be careful as it could easily get me speeding tickets.
Speeding is not what I was after but just a more drivable vehicle on the road and boy have I achieved that.
Tomorrow I will take it on a long test drive and report back
also try to scan the print out and post
If anyone thinks it cant be done your welcomed to take it for a drive especially if your thinking of spending big money on engine transplant you might want to think again.
The Perky is fine outback in flat country but over here on the eastern seaboard we have to cross the range and climb hills every time we head in any direction and it becomes a tiring exercise rowing through the gears. Fitting the auto to the Perky made a massive difference to how it drove as it just got on boost and held it up through the gears but even highway running still saw us being overtaken by laden B doubles, chuck in a hill and everything passed us including the caravannner that sat on 85kph up hill and down dale.
So now the 6BT is in, just have to hook everything up!
- Peter Davis
So that is a jump from 64 Hp to 86 Hp, I assume in 4th gear. Be interested to hear what its like at 100kph in 5th, EGT that is.
- Frank
He is still to reconnect his intercooler, so it will be interesting to see what difference that makes wrt hp.
Martyn's Oka is very quiet, the soundproofing of engine noise is impressive. It is a background noise and no more, even at 2500 RPM.
Wind the window down and you can hear the turbo whistle from the air intake. I also checked his tacho (it reads low but is within 50-100 RPM across the whole rev range), because I didn't believe an Oka could be that quiet at those RPMs.
A lot nicer vehicle to drive than mine, particularly in traffic, accelerates very well, feels like an automatic, just leave it in 3rd gear. Time to start working on air inlet, exhaust and soundproofing on mine i think.
cheers,
Frank
- darren lilly
- Peter334
mort wrote: I just spent an hour typing only to be told your session has timed out
Sorry Martyn, this can be frustrating if diverted in the middle of preparing a post. The session time-out is set to 2 hours and I can extend it (but can't be indefinite).
If you get this type of problem, hitting the Back button sometimes reveals your typing which you can copy and paste somewhere else (eg a text file) for safekeeping.
If you need to leave a editing session open, before leaving, do the same, copy all your text so it can be pasted in again later.
Alternatively, for a complex posting, prepare the text off-line in a text editor/Word etc and then copy/paste into the Forum entry box.
