Rust in bottom door panel
Keeping interior of font doors completely water tight seems to be impossible given the design of the winder, flock channels and rubber seal across the bottom of the window.
Have not fully opened them up yet but hope to be able to put in some sort of effective internal self draining to ensure water is always channeled out of the top section and when necessary down and out of the bottom corner section when doors are shut no matter what angle the truck is on.
Ideal would be to paint/seal (2 pack?) all the inside of the doors when panel work is done. Would also like to be able to get better general access to inspect the inside of the bottom section. This would be difficult to set up given any open-able inner panel would be hard to seal as it is outside in the weather under the truck below the door seal when the door is shut.
Any ideas or feedback, suggestions from anyone who has been in here and tried anything to arrest, manage the rusty door problem would be most appreciated.
cheers
Most vehicle doors that I've seen are of the design where water is supposed to flow out the bottom.
The biggest problem is that Oka didn't apply any rustroofing or treatment to bare steel or enclosed body sections anywhere in the body building process which is why we now have problems.
Combined with a lack of drain holes in box sections that are sealed and the inevitable moisture from either condensation or leaks is why most Oka's have corrosion problems. We should also remember that they are all probably well past their "designed" lifespan
A factory stough up, as Peter said, sever lack of rustproofing
The fix!!
Re,skin doors, rust proof & 1/2 in holes to let water out.
OKA parts, exchange poors or skins
The insides of our door panels seem to be covered with a sticky waxy coating, fish oil? maybe sound deadening?
The folded edges of the door (and rear hatch) skins is where most of our rust starts and travels inboard from there. I'm sad to say I just cut out what I can, derust with converter solution (eg Ranex Rustbuster ), paint and and cover/camouflage with thin aluminium sheets.
Our worst rust areas are around the bus rear window frames, gutters and the lower sides of the windscreen surround. I patch things up but the only permanent solution is re-skinning and I don't see that on the horizon.
To get access I have removed half of the inner door skin to be replaced with a new 2 packed duragal panel.
Have cleaned up door frames which look good except for short corner section in the very bottom corner that has been replaced.
Have also cut out small triangular corner of outer skin and have a new prefolded piece ready to tack in.
I had to unfold a short section of the outer skin from the bottom section of the frame to get access. I have thoroughly cleaned off any surface rust from the inside edge of the skin and from the facing piece of frame and cleaned with rust converter. Both surfaces are now shiney clean.
..I plan to refix the skin along the frame with sikaflex 221 held down with stainless rivets.
I have to rebend the unfolded short section of outer skin around the edge with hammer and dolly.
I would like to paint this bit first because the duragal has been compromised but the paint will likely fracture with the bending.
I will be coating the mating surfaces of the channel and skin thoroughly with sikaflex before riveting.
Question?????..
Should I paint these edges before folding them down but the paint will probably crack with the bending or let the Sikalex adhere directly to seal the unpainted compromised raw metal??
..The outer skin/frame joints will be sealed and repainted thoroughly from the inside and outside after fixing before I sikaflex and rivet the new inner skin on.
tuch up galv airasol takes a belting with hammer
Rivits are good, avoid spot welds,
David aluminum & galv oxidise together & rust faster
I showed pic,s of #95 with alloy patch ups
- John and Bronwyn
www.bluescopesteel.com.au/howto/avoid-incompatible-metals
I am unsure of the ones labelled Yes*. I would have thought that at least some of these would be better described as No? (Eg Zincalume / galvanised, and aluminium / galvanised).
I have seen he results of one of the No's - water from copper onto colourbond.
I would be painting/protecting the surfaces first to minimise the effects of any retained moisture, since once you bend up and seal the joint you can no longer get at the insides. Can't be too careful.
outyonda wrote: David aluminum & galv oxidise together & rust faster
OYDA thanks, I only put aluminium sheet over a derusted and protected surface/hole, not metal to metal.
It's purely cosmetic.
- Paul and Sue Crompton
Rick, obviously the best solution is to replace the door panel but you may also open up another can of worms as the frame may also be rusty. In an ideal world that is what you would do. Second best option would be to cut out the rust and weld a new panel in but difficult if you are not a panel beater.
I have found that with surface rust only, which is not too bad, if you sandblast it and coat the inside with a bitumen based rustproofing, what seems to happen is the metal is porous and it seems to absorb the oil out of the bitumen and also the bitumen helps to stop the oxygen getting to the metal. If there is no oxygen, it will not rust and maybe recoating the inside with a bitumen base or fisholene to try to slow it down. There are panel glues which are used now made by 3M which are very strong for gluing steels and also there is a new one by 3M that they are using on new chassis called Impact Resistant Bonding. These come in a 2 pack tube which are about $100 for a small tube but unfortunately you need a special gun to apply it and that is about $400. Obviously the best advice you can get for Sikaflex is to go on their site or ring them for advice. You would also find panel bonding and structural panel bonding on You Tube. I should also make a comment that my trade is panelbeater and spraypainter restoring old cars.
Sikaflex is not designed to be stuck onto paint as it would only be as strong as the paint. When you use Sikaflex you are supposed to use it with Sikaflex primer to promote adhesion. Most people don't as the primer is a lot more expensive than the Sikaflex itself.
Peter, I know you are not supposed to mix different metals together ie aluminium, galvanise or zincalume, however, my house and my garage have a zincalume roof and colourbond gutters for the last 30 years. Touch wood, I have been lucky that they have not deteriorated but I have found over the years that any leaves or debris that go on to zincalume and stay wet for a little while certainly seem to rust out quickly but the colourbond with the leaves seems to resist.
Paul.
Paul Crompton - OKA 168
- darren lilly
1. the drain holes needs to be bigger and cleaned out from time to time.
2. it is important to make sure that you use enough sika to ooze out and seal the panel to frame. I see that as one of the biggest problems as moisture gets between panel and stays there.
If you are going to use sika then you dont need to rivet as the sika will give an excellent bond the trick is not to clamp too tight as you squash out all adhesive and the rivets act the same as clamping so then why use an expensive adhesive and use a roof and gutter silicone as you only need a sealer.
Paul is right your top is only as good as the bottom so you may have the best adhesive but if it is stuck to a poor quality paint then its only as good as the paint.
Martyn (its an OKA thing)
My wife uses lemons to good effect around the house just as a thought we have 2 trees and give away or throw out more lemons than we use maybe I could save the juice and give the whole OKA a bath it might save me a lot of sandpaper.
- darren lilly
- darren lilly
Had to rush to get the door finished to be in a useable state by the Labour Day weekend for family's hiking trip (not me!) around Wilson's Prom so I don't have any pics of the door opened up before or during the repair.
OKA camped our free "secret" spot by the old fishermen's sheds at Corner Inlet on Labour Day showing repaired door below...
I cut the interior doorskin along a line just above the level of the bottom of the plastic (fibreglass in my case) door trim and removed the bottom half by drilling/grinding out the spot welds round the lower frame.
The inside of the door turned out to have been slathered in fish oil or some other rust inhibitor and once I got past the red dust inside found all was in perfect condition except the very bottom section which was rusted out (sorry no pics)
The bottom angle section of the frame had to be cut out and a new one folded and welded in. I also had to slice out the very bottom corner of the outer skin and weld in a new piece.
All of the inside of the door skins and frames were thoroughly cleaned, welds and edges of the original duragal coated with Galmet Coldgal then Duragal. Any raw metal was etch primed and then everything primed inside and out with acrylic primer then painted with two pack.
Doorskins were re-assembled using sikaflex 221 (nothing in a tube that I hate more!) and stainless rivets. Rivet holes drilled before painting and painted surfaces to be joined with sikaflex prepped with scotch-brite and prepsol.
The reason for the rust in the first place was inadequate drainage from the bottom section of the door combined with insufficient sikaflex to properly seal between the bottom frame and the door skins. There were two holes in the mid frame allowing water to flow into the bottom section but there were only two holes in the bottom section located as shown with arrows on the repaired door below ..
The hole in the sloping section was useless to allow water to get out and the only other one at the hinge end was very small and partly blocked with dirt. If the OKA was parked uphill water could fill the rear triangle of the bottom section up to 100mm deep!!
There are now four large holes in both the mid frame and bottom frame sections to let water out.
All joints now fully sealed and all surfaces thoroughly painted inside and out.
I also used silicon windscreen sealer at each end of the rubber at the bottom of the window to try to reduce the amount of water getting down into the door as much as possible. This helps but given the design of the door it is impossible to keep it out completely.
With your panache for excellentness, how would you suggest I dealt with this (once I've done all my other upgrades of course)?
The bottom of the windscreen surround flexes and cracks and eventually rusts out. I derusted/patched and covered it up (5 years ago) but a permanent solution would be preferable.
