Changing GCM on XT Oka
- Jo and Al
19 Aug 2018 14:49 #1
by Jo and Al
Big Al & S'Jo
OKA 159
Jo and Al created the topic: Changing GCM on XT Oka
Has anyone been able to change their GCM to 9000Kgs?
We have a XT Bus Body converted to a campervan by Oka from factory.
It's GCM is 7000Kgs. Bus weighs fully loaded approx 6000Kgs.
Would like to tow 2500Kgs car trailer.
Your assistance much appreciated.
Alan
Alan
Big Al & S'Jo
OKA 159
19 Aug 2018 17:17 #2
by Ralley
Ralley replied the topic: Changing GCM on XT Oka
I did get my XT to 5.7 gvm and 8.2 gcm. I hope to go higher now I’ve upgraded the front to a 70 and an 80 in the rear.
The following user(s) said Thank You: Jo and Al
19 Aug 2018 17:23 #3
by Peter_n_Margaret
Peter_n_Margaret replied the topic: Changing GCM on XT Oka
We had our 196XT GVM increased from 5500kg to 6600kg and the GCM increased from 7000kg to 9000kg.
The GCM required mostly calculations on power and torque to ensure that it can start from stationary on a 12% slope and continue to drive on a 20% slope when at GCM.
The GVM require practical brake testing and an assessment that the rest of the vehicle was capable.
It was done by an engineer approved by the SA RTA and a Blue modification plate was issued.
- Jo and Al
20 Aug 2018 09:35 #4
by Jo and Al
Big Al & S'Jo
OKA 159
Jo and Al replied the topic: Changing GCM on XT Oka
Hi Ralley, we are trying to get info on a XT running a 4cyl Perkins, are you the same specs?
Thanks Alan
Thanks Alan
Big Al & S'Jo
OKA 159
- Jo and Al
20 Aug 2018 09:37 #5
by Jo and Al
Big Al & S'Jo
OKA 159
Hi Peter, thanks for your info, are you running a 4cyl Perkins or have you upgraded?
Regards Alan
Regards Alan
Big Al & S'Jo
OKA 159
20 Aug 2018 15:48 #6
by Ralley
I did the upgrade before I upgraded the rest. It was already running twin shocks, NT springs and 1" shackle pins.
20 Aug 2018 22:31 #7
by Peter_n_Margaret
Yes, standard Perkins.
10mm top spring leaves, 305/70R19.5 tyres.
21 Aug 2018 06:59 - 21 Aug 2018 07:06 #8
by outyonda
outyonda replied the topic: Changing GCM on XT Oka
Jo & Al
each stage has it's own regulations, WA rejected the plan for national transport regulations because the other states were too backward & would not rise to WA standards.
you need a WA engeneer to inspect & upgrade your GCM
1" pins,springs,heavy axles tyres engineered shocky mounts etc etc
OKA parts can point you in the right direction with an engeneer who knows what an OKA looks like.
Brett
Brett
Last Edit: 21 Aug 2018 07:06 by outyonda.
The following user(s) said Thank You: James and Usha, Jo and Al
- alanj
23 Aug 2018 14:58 #9
by alanj
alanj replied the topic: Changing GCM on XT Oka
Hi Jo and Al,
I'm keenly interested to see how you progress with your upgrade. I made some enquiries about this earlier too but am yet to start the process.
Can I ask how far you've progressed? Did everyone have to upgrade to NT specs in order to successfully achieve the upgrade?
Alan
Alan
