Engine oil - good value
  • Peter_n_Margaret
  • Peter_n_Margaret's Avatar Topic Author
13 Nov 2019 09:47 - 13 Nov 2019 09:48 #1 by Peter_n_Margaret
Peter_n_Margaret created the topic: Engine oil - good value
I have been using LSA (Lubrication Systems Australia) 15W40 Diesel Ultra (semi synthetic) engine oil in the Perkins for 15 years. I most recently paid $115 for 20L. Probably suitable for other diesel engines too.
LSA are currently selling it over the counter for $90/20L drum.
www.lsaoils.com/
Last Edit: 13 Nov 2019 09:48 by Peter_n_Margaret.
14 Nov 2019 11:40 #2 by packhorse
packhorse replied the topic: Engine oil - good value
Peter, how many K's are you running the LSA out to between changes & do you run an additive ?
cheers
Mick
  • Peter_n_Margaret
14 Nov 2019 19:53 #3 by Peter_n_Margaret
Peter_n_Margaret replied the topic: Engine oil - good value
Typically 10,000km (occasionally shorter for convenience between trips).
No additives.
15 Nov 2019 05:23 #4 by Holmz
Holmz replied the topic: Engine oil - good value
I was blowing through oil at a pretty fierce rate, and on the change put in some redline, and the consumption rate dropped to a litre in 2000km.
So I suspect that the LSA is a good way to go too., and certainly a much better value.
Redline does do a zinc/phosphorus additive (breaking lube) that adds back in the stuff that has been lacking for the cam and lifters... if one is overly concerned about those parts.
