Panel Bonding
Alister McBride wrote: Hi all, what are people using to stick their body panels on with? I used Sika 252 last time and it worked well but at $35 a tube from Bunnings is pretty steep! Any alternatives? I've seen Sika 221 also but not sure if it's up to the task? Or the best place to buy the Sika? TIA
From my April 2018 post…
“Talked to Sika Au, and they recommended... "Sika primer" and "Stia activator G+P" followed with "Sika 252" with a 4-mm bond thickness.“
To pass on to the group here and to have a permanent record, i had the following responses to my question on the facebook groups:
- So far I have found Bunnings about the best price for them and the best range. If you have a trade card (just need an abn) you save another 5% or so.
I think I have used the 221 and 227 for some things. I figured the Body fixing one the best for panels, but think it is the dearer option. - Ps I think I have been using 227 for interior sealing, but not panels. 221 is more a construction one but you might be right about 252 being the superior high strength. I usually refer the the example image on the labels when buying it.
- Terason 989. Adhesive sealer - ABC adhesives sell at a good price, I buy by the box. $ 21.00 per sausage. Priced here at a hardware shop was $ 48.00 per.
- If you are using a lot look at getting the sausages from an industrial outlet.
- I am using Soudal T-Rex Power Fast Grab SMX Polymer Adhesive 320Kg/10cm2. Paying around $10 Tube - Used Trex on my camper trailer rebuild with great success Using it now on the coffin panels Permanently flexible I found it at a local sand and metal place, order it by the box of 6 in black.
- Bostic seal and flex works for me . Regardless of what you use rough up the face your trying to adhere to with a scotch brite .
- (re finding a well priced supplier) - Try floor sanding supplies down there / I buy it buy the box off them up here @floorsanderstrade
- I use Fixtech, from the marine industry
So far, my pick is the T-Rex Fast Grab based on specs. It's a little bit stronger than Sika 252 and a tiny bit less flexible but at a third the price seems the way to go for me.
Alister McBride wrote: Thanks Holmz, at the strength ratings we're talking about with these products i think good surface prep is essential! me.
I used the forum’s search feature as it is a permanent record.
I do not know how to search FB.
Bunnings usually has the Sika on sale once in a while. Usually when the stuff if about out of date.
I also chuck em in a beer fridge.
And the primer they often do not have, and need to order in, so some planning pays off.
3M also makes a strong one, but you cannot cheese wire it off, it is pretty permanent.
At least the Sika gear gear can be removed with some work and not destroy the panel.
It is probably more like shoe laces, where the colour of the laces does not affect the shoe staying on… so I doubt it matters much what one uses if the intent to keep it on.
The Sika technical fellow said that the main problem is people often do not have enough applied, and it needs to have enough depth to allow some flex as the panels expand and contract… so not just a thin layer of vegemite thickness.
Despite its use and a major prang, not a single glued joint has failed in that time.
I have just purchased the panels from Vanglass to build #077. They use another adhesive and I have some on the way @ $20 per sausage. When they arrive, I will post the details.
I did a bit of messing with a TRex fast grab and found that its surface adhesion was relatively poor compared with Sikaflex.
I used a product from here silicone.com.au/ they are in Melb and make a range of products.
When I rebuilt the back all panels were glued with their auto body adhesive which was 5 yr ago no screws, rivets etc and nothing has come loose.
I think I paid about $14 per tube per box so at that price I made sure I used enough to have full coverage dot just a thin bead.
Be careful because it grabs and and if you want to move the sheet it is hard to let go.
Wurth Bond + Seal.Peter_n_Margaret wrote: I have just purchased the panels from Vanglass to build #077. They use another adhesive and I have some on the way @ $20 per sausage. When they arrive, I will post the details.
