external sunvisor fixings question
- Dave Blythe
- Online
02 May 2022 16:11 #1
by Dave Blythe
Dave Blythe created the topic: external sunvisor fixings question
Anyone know the thread/size of the 2 setscrews securing the centre part of the external sunvisor to the cab?
My OKA is 300klm away and I'd like to arrive there with the right fixings.
03 May 2022 05:59 #2
Peter and Sandra OKA 374 replied the topic: external sunvisor fixings question
Some were held on with tek screws, some with nutserts, most have been modified at some stage.
I'd suggest going with 6mm nutserts and taking the required drill and tool to insert them along with stainless bolts to suit.
I did that to mine after having it pull up when meeting a truck coming the other way with a strong crosswind.
If it had nutserts from the factory the original nutserts that Oka used were flush fitting ones with virtually no grip on the facing side of the panel and relied on the rear flange doing the gripping and and a small taper on the front.
Roll on 25+ years and a bit of corrosion they will spin when you try to undo them or tighten them. I made a thin steel tapered fork out of 3mm x20 flat bar which I tap in between the thing being held and the surface this often locks the nutsert enough to enable removal so you can replace it which can often be a bugger of a job.
The following user(s) said Thank You: Dave Blythe
- Dave Blythe
- Online
03 May 2022 07:54 #3
by Dave Blythe
Dave Blythe replied the topic: external sunvisor fixings question
Thanks for the comprehensive reply Peter this is exactly what I needed to arrive prepared.
FYI - I'm dropping Her off to Kelvin Marquand later this month for Her facelift.
- Dave Blythe
- Online
11 May 2022 16:51 #4
by Dave Blythe
closing off this thread I started.
drilled dia 9mm and installed 2 x 6mm nutserts in the centre run of the sunvisor did it fine. Coupled with a good dob of silicone goop to bed it down.
