Wheel lug thread pitch
10 Dec 2012 21:28 #1 by James and Usha
James and Usha created the topic: Wheel lug thread pitch
Does anyone know what the thread pitch is on the wheel studs? I'm going to get some new lugs and need to know this.
Cheers - James
#072
10 Dec 2012 23:00 #2 by Joseph Baz
Joseph Baz replied the topic: Wheel lug thread pitch
James,from memory they are 5/8 UNF,can give you a definite in the morning.
11 Dec 2012 00:23 #3 by Peter and Sandra OKA 374
Peter and Sandra OKA 374 replied the topic: Wheel lug thread pitch
5/8 UNF is correct but you will need the actual measurements and the degree of taper on the nut when ordering wheel nuts to suit the wheels you are fitting. Not all wheels have the same taper angle on the nut seat.
11 Dec 2012 12:40 #4 by James and Usha
James and Usha replied the topic: Wheel lug thread pitch
Thank you both.
#072
11 Dec 2012 16:47 - 11 Dec 2012 16:48 #5 by Moose2367
Moose2367 replied the topic: Wheel lug thread pitch
They are 5/8 UNF and 18TPI (threads per inch) They are also a 60 degree taper from memory, that's what i ordered for my alloys and they are the right ones.
Most wheels are 60 degree, the only other ones i know of are 45 degree and bolts, 60 is the most common
Last Edit: 11 Dec 2012 16:48 by Moose2367.
11 Dec 2012 17:21 #6 by Peter334
Peter334 replied the topic: Wheel lug thread pitch
Paul Knot has them i brought 16 of them just awhile ago second hand $10 each and in good nick
11 Dec 2012 17:28 #7 by Moose2367
Snake racing is the cheaper option for studs and nuts, stud part number is S796, they have nuts to suit, plus free postage
12 Dec 2012 08:34 #8 by Frank
Frank replied the topic: Wheel lug thread pitch
trailer parts in bayswater WA also have studs and nuts in both 45deg and 60deg ( www.trailerparts.net.au ), around $3 each if my memory is correct.
from their web site
Contact Information
4 Katanning Street
BAYSWATER WA 6053
Phone: (08) 9279-5777
Fax: (08) 9377-1156
Bayswater Sales:
81 Forsyth Street
O'CONNOR WA 6163
Phone: (08) 9314-2222
Fax: (08) 9337-1897
O'Connor Sales:
61 Challenge Boulevarde
WANGARA WA 6065
Phone: (08) 9302-2800
Fax: (08) 9302-2600
Wangara Sales:
The following user(s) said Thank You: James and Usha
12 Dec 2012 19:13 #9 by Joseph Baz
Frank,be careful with trailer studs unless they can guaranteed the grading of the studs as the OKA's are a tad heavy.
13 Dec 2012 06:34 #10 by Oka Parts
Oka Parts replied the topic: Wheel lug thread pitch
Oka Parts Australia has wheel nuts and studs. Be carefull using non standard nuts.
OKA Parts Australia, 24 Murphy Street, O'Connor WA +61 892236195
15 Dec 2012 09:07 #11 by Peter and Sandra OKA 374
If fitting alloys you need to know hte taper angle and the depth of the hole in the wheel to get nuts to suit. I bought mine from a mob in the US, 48 nuts cost $50 delivered to my door.
