XT & LT Oka - Running Gear Differences
- Paul and Sue Crompton
11 Mar 2013 11:00 #1
by Paul and Sue Crompton
Paul Crompton - OKA 168
Paul and Sue Crompton created the topic: XT & LT Oka - Running Gear Differences
Hi folks, I was wondering if anyone can tell me what are the differences in the running gear between the 2 models. I would expect the gearbox, transfer case and tail shafts would be different. The reason I ask this is because I have an LT and I only have a parts manual for an XT. So I am hoping if people know the differences on the running gear ie bearings etc, they could let me know so I could still use the XT parts manual with confidence. Thanks Paul.
11 Mar 2013 11:09 #2
Peter and Sandra OKA 374 replied the topic: XT & LT Oka - Running Gear Differences
Both share the engine and gearbox with minor differences.
Both have the same axles front and rear again with minor differences.
Cooling system the XT radiator is different to LT other wise pretty much the same
Fuels system pretty much the same.
Electrical engine side of things similar but body wiring different setup.
Transfer case in XT is different, XT has married NP205, LT has divorced Rockwell
Tailshafts different on both lengthwise with LT having a jackshaft between gearbox and transfer.
11 Mar 2013 11:11 #3
by Outback Jack
Outback Jack replied the topic: XT & LT Oka - Running Gear Differences
There is a fair bit of difference.
Cooling system
A/C
Transfer Case
Brake is changed from Cable to Hydrulic
Diffs maybe had some changes
Cab layout etc
Electricals
Plus things I have missed, Better getting a manual of OKA Parts or David H.
Cooling system
A/C
Transfer Case
Cab layout etc
Electricals
11 Mar 2013 19:37 #4
by Joseph Baz
Joseph Baz replied the topic: XT & LT Oka - Running Gear Differences
Do you mean Clutch changed from cable to hydraulic?
The brake hasn't change!
11 Mar 2013 20:04 #5
by Outback Jack
Yes clutch has changed. Sorry
- Cando
11 Mar 2013 21:01 #6
by Cando
XLT-112
Cando replied the topic: XT & LT Oka - Running Gear Differences
Unless you have a hybrid like us, the clutch is still cable while the radiator is LT ..
XLT-112
- OKABloke
12 Mar 2013 07:58 - 12 Mar 2013 07:59 #7
by OKABloke
OKA 4x4 Facebook Page
OKABloke replied the topic: XT & LT Oka - Running Gear Differences
OKA Manuals: XT and LT in PDF Format available on CD. $110 Delivered
Includes Engine, Service and Parts Manuals
Last Edit: 12 Mar 2013 07:59 by OKABloke.
17 Mar 2013 09:58 #8
by Outback Jack
Think Cando is down that way,so should be able to pop in and grab it.
