Speedo compatibility between LT and XT
Not easy to get at on a bus model though.
- The Worb
I like the red, it seems to suit the OKA. If I every paint 351 I will give it a look.
What size and type tyres are you running. I am in about 3 minds what to do.
Good 16" on the standard rims or change to Eagle Alloys which allow a bigger choice of tyre.
Good one, I wish I was close to tracks like this.
The Worb
Dubbo NSW
I am the same, I am considering 16 inch Eagle Alloy as well, and they was very popular. However I think now days there are other options in 17 inch etc etc.
Previously the wires that went originally to the Rockwell TC were just hooked straight to the sender on the replacement Nissan TC and it worked perfectly. Didn't seen to matter which way around they were either.
My NP205 has a speedo drive in it but I think this may be a minefield so I have decided to setup like the XT
Q. I have orderered the correct XT sensor from info in a post put up previously, but I am now wondering if it will be compatible with the LT speedo, anyone done this? Is the LT speedo the same? And is there any polarity with the wire hookup?
- OKABloke
OKA 4x4 Facebook Page
In the end I just used the TOSS output from the auto to provide the signal which works well.
PeteFox wrote: And is there any polarity with the wire hookup?
Pete, yes there is, although the Turck sensor is supposedly polarity and overload protected.
First confirm that you ordered the AN6X sensor not the AP6X (I made an error in transcribing the part number from the old website, now corrected).
If you're in doubt over the wiring, here are the sensor connections. I suggest you check the +12v and ground on the wires from the speedo, with the ignition on, before connecting the sensor. The voltage on the signal input from the speedo can be anywhere in between.
For a Turck BI8U-M18-AN6X, the sensor wires are:
Brown (BN) wire is +12v
Blue (BU) wire is Ground
Black (BK) wire is the pulse signal to the speedo (the Load is internal to the speedo).
Whoops!
If you're electrically minded you might follow my logic.
A VDO speedo can handle several types of sensor on its input pin. The main criteria is that the input voltage pulse should pass by it's sensing voltage and back, which I assume is around 6v. It doesn't matter if it starts high and goes low or vice versa.
Refer to the graphic below.
In the AN6X, the signal output is normally high, the output transistor is off and the output voltage is pulled up to +12v by an internal load in the speedo. The output pulses low (the transistor turns on) when the proximity detector senses a metal object passing by (the tangs on the handbrake drum in the case of an XT).
In an AP6X, the opposite occurs, the signal output is normally low, the output transistor (different type) is also off and the output should be pulled low by a load to ground. The output pulses high (the transistor turns on) when the proximity detector senses a metal object passing by.
Both ways should work fine, the unknown is that there isn't an obvious load to ground for the AP6X circuit in the VDO speedo. Depending on the speedos's internal circuitry, it might have a load to ground (or something which pulls the input signal low) built in anyway. But if not an external resistor load should do the trick.
So unless you can easily and cheaply exchange the AP6X for an AN6X, I should give this option a whirl. The wiring is identical so try it without the resistor first, it might work. If you try this the internal load connection on the back of the speedo (if any) should be removed.
dandjcr wrote: Pete, no need to panic, I believe the AP6X can be used although I haven't tried it myself, I worked this out to assist another Oka owner but I don't have the results yet.
Dave, thanks for the info, but I can deal with simple DC circuits but once you mention resistors then my brain's resistor kicks in.
The simple way out was to source the correct one . Bought out of the US for $28, too cheap to bother messing around.
The "AP6" had no cable but a 4 pin socket, all too hard.
