Front drive shaft safety hoop
- Len208
06 Jun 2013 15:46 #1
by Len208
Len208 created the topic: Front drive shaft safety hoop
Saw a large Isuzu tour bus which had instead of the metal safety hoop,had a plastic covered cable suspended chassis rail to chassis rail under the transmission shaft.A simpler more flexible solution possibly
06 Jun 2013 21:07 - 06 Jun 2013 21:17 #2
dandjcr replied the topic: Front drive shaft safety hoop
Len, a chain/cable may prevent a broken drive shaft from digging into the ground but a steel hoop will also prevent it flailing around dangerously.
We had a front drive shaft which came loose at the rear UJ. It flailed around damaging the transfer box linkages but we were travelling slowly and were fortunate it didn't damage the gearbox, clutch housing or worse.
The bolts holding the small UJ straps came out. I've since replaced the straps with U bolts for reliability.
Last Edit: 06 Jun 2013 21:17 by dandjcr.
