REAR DIFF
- Peter334
16 Jun 2013 15:46 #1
by Peter334
Peter334 created the topic: REAR DIFF
Can anyone tell me if these numbers represent what ratio I know it is an open diff no other numbers saying what ratio it is 8-3095 DANA D 34808 PAL 397 39.8 65 . cheers peter
16 Jun 2013 18:00 #2
by Joseph Baz
Joseph Baz replied the topic: REAR DIFF
Peter,
The OKA is a 4.88:1 ratio as Factory std,if in doubt count the teeth of the crown wheel and the pinion and divide the crown count by the pinion and that will give you the ratio,Those numbers do not represent the ratio
- Peter334
17 Jun 2013 03:24 #3
by Peter334
Peter334 replied the topic: REAR DIFF
Thanks I did now the ratio but I was hoping some one would have an idea what they represented it would have saved me from taking it apart again and loosing the new oil again ,cheers peter
17 Jun 2013 18:37 #5
by Joseph Baz
Peter ,the bill of materials number is good if you know for certain the origin of the diff but with the OKA's being a bit long on the tooth it can be a replacement housing and not the original,the only thing that I make sure is that crownwheel and pinion are matched sets,you will find the numbers etched on the head of the pinion and the side of the crown wheel.
