Resting on Diff or Discs
- Frank
18 Jun 2013 15:42 #1
by Frank
Frank created the topic: Resting on Diff or Discs
I'm wanting to remove all four wheels and rest the Oka on its diff or disks.
According to my measurements the diff housings will hit the ground first (by about 5mm, but I could be wrong).
My mind tells me that it is probably preferable to keep the forces where they should be. So I'm thinking a piece of wood under the brake discs.
Is there any likelihood of damage to the discs, etc in doing this?
thanks
Frank
The reason why is so my engine crane will have the required height to lift the roof top camper onto the Oka.
Alternatively, has anyone got a hiab (Perth,WA) I can park next to for 5 minutes while they lift the camper from the trailer to the Oka.
thanks
Frank
18 Jun 2013 17:41 #2
by Joseph Baz
Joseph Baz replied the topic: Resting on Diff or Discs
Frank,
I have a forklift in the workshop if that is of any help.
- Kav1050
18 Jun 2013 18:11 - 21 Jun 2013 07:31 #3
by Kav1050
OKA 423 Shane and Lisa
Kav1050 replied the topic: Resting on Diff or Discs
Frank i have an overhead crane 10T that can be used to lift it on for you.
Just PM me with your mobile number and ill give you a call if you if your interested.
Location is Rockingham WA
Kav
Kav
Last Edit: 21 Jun 2013 07:31 by Kav1050.
- Frank
18 Jun 2013 20:54 #4
by Frank
Frank replied the topic: Resting on Diff or Discs
Joe, Kav,
thanks for the offers.
Kav, will try Joe's offer first as he's closer.
cheers,
Frank
cheers,
Frank
- Peter334
21 Jun 2013 18:11 #5
by Peter334
Peter334 replied the topic: Resting on Diff or Discs
Although the rotors are pretty robust items they at no time carry weight the hubs do ,if I was you I would put blocks under the diff axel housing to the same height allowing compression of the timber so you are not resting on the rotors ,that's my view I have never done what you are going to do. cheers peter
