HF Radio location in cab?
I've just started a long trip and in the hurry before we left i decided to install the HF radio on the way. Looking at possible locations though i think it would be much easier to install it in the dualcab module so I can only use it in the rear of the vehicle. My theory being that from what i can understand, use of a HF seems to always be while stationary and so it wouldn't matter about location...? In fact a lot of people just seem to put the antenna up when they need to use it...
Any input would be appreciated as i don't know much when it comes to using HF's.
Cheers, Alister
In the "old" days before vehicles gained much in the way of electronics we always used them on the go as there was little interference from the vehicle. As time went on though the increased electronics led to increased interference with some vehicles being impossible to screen so if the engine was on the HF was off!
I've not put one in an Oka for many years but from memory they were pretty good interference wise but modern accessories like GPS, TPMS etc all create interference of varying degrees. I'd reckon solar controllers, regulators and the like would all cause problems.
One of the main reasons I've not put my Barrett in 374. Easier to cart the satphone.
In Oka's I used to mount the main transmitter behind the drivers seat so that it could be reached from the rear and when the remote control heads came into vogue put them on the dash on the passengers side towards the centre.
Antenna's of course on the existing bullbar mount.
But this means few people will be using HF during the day so having the radio accessible from the cab while driving is not that useful. Also a bullbar antennae, which are quite large, would need to be raised while moving and subject to vibration and damage.
HF comms is certainly possible during the day and will be better on higher frequencies (for emergency selcall contacts, not many travellers will be listening then), but I think the best arrangement is to have the radio in the rear cab and use it when stationary in the evening/morning when it's easier to erect a tall antenna.
But as Peter says, HF reception is very sensitive to electrical interference from computers, inverters, fan speed controllers, battery chargers, nearby power lines, generator ignition etc., in fact almost any electronic equipment. HF radios have very sensitive receivers so electrical noise affects reception of weak signals (micro-watts) but not transmission (up to 100 watts), so even if you can't hear a signal, there's a good chance that an emergency transmission would still be received. You'll quickly learn what's causing noise by progressively switching things off with the radio on.
The practical considerations of locating an HF radio are proximity to a solid 12v 20amp supply (preferably the starter battery so you have power available for emergency calls) and as short an antenna lead as practical from the radio to the antenna/bullbar. The radio case and bullbar should also be effectively grounded to the vehicle chassis/body with a separate grounding wire.
Although radios usually have impressive looking heat sink fins, they don't actually get very warm since they only consume significant current during transmission (it's proportional to how loud you talk) so they can be tucked away in a cupboard as long as you can still access the front panel easily.
NEVER connect the negative ground for the HF to the negative on the battery rather at the other end on the chassis/body.
The reason for this is that if the main ground lead for the starter becomes loose or adrift the starting current will take the path of least resistance which can be through you expensive HF radio. They don't work after such treatment and usually require total replacement. I've had to break that bad news to a few owners over the years.
You could fuse both positive and negative legs but that just introduces another possible poor connection/failure point, best to just avoid connecting it to the negative of the battery.
I've made a mount for the Codan autotune antenna that puts its base 700mm above the rear RH corner bumper with the whip base about level with the roof. Don't know how effective it will be but it's better than at the front. As time runs out I havn't decided which way I'll go.
There are still some QMac 50 watt HF sets out there which are quite small and would fit well in the LT dash where the silly clock goes. The later version of these sets are very good with the export version highly sought after.
Dean and Kaye Howells wrote: I've made a mount for the Codan autotune antenna that puts its base 700mm above the rear RH corner bumper with the whip base about level with the roof. Don't know how effective it will be but it's better than at the front.
Deano, as long as the mount doesn't vibrate too much and is effectively grounded to the Oka chassis/body, that location will be fine. The whip will be above the Oka which is where it will work best, and the Oka roof acts as a nice ground plane to get the signal into the air. The whip might get attacked by branches though.
The roof rack may detract from the antennas efficiency but I wasn't game to make it any higher, but it is on the drivers side so should miss most trees etc.
I wasn't happy to have it on the bull bar as I thought this was too prone to damage, especially on the passenger side. "You're not putting that bloody thing on my side" said Kaye who is wont to take photos through the windscreen whilst travelling and it's far too intrusive to mount on the drivers side. So this is plan 'c' so to speak.
- OKABloke
In the Up Position
Travel Position, Just add the Whip before erecting.[/size]
OKA 4x4 Facebook Page
Dean and Kaye Howells wrote: The roof rack may detract from the antennas efficiency but I wasn't game to make it any higher, but it is on the drivers side so should miss most trees etc.
Deano, the roof rack won't make much difference to antenna efficiency, it would have to be completely surrounded by conducting material (like a Faraday cage) to make a significant impact, but it could affect it's directional performance (better in one direction than another).
Higher would be better but there are plenty of examples of similar rear antenna mounts, eg this Kaymar mounting .
Barett's preferred and acceptable locations are here:
Antenna performance is very subjective and there is no perfect or completely wrong location, even lying on the ground works. I recently got a perfect reception report from Alice Springs (in Adelaide) with my antenna lying on a wheelie bin.
Don't forget to carry a 9m length of insulated wire as a good emergency antenna. Just connect it to the antenna lead and chuck it as high as you can make it into a tree or over a bush, or just lay it on the ground in the general direction of the required transmission. Most radios have a transmit light which glows while talking, the brighter it is the better your radio/antenna is working.
Unfortunately auto tune antennae are not as efficient as a tall vertical whip antenna would be (and a tapped whip is somewhere in between) but they are convenient for selecting different channels.
Joseph Baz wrote: Please excuse my ignorance in this topic,I have a Codan left over from my Halls Creek days and I'm wandering wether or not is worth installing the unit as I been told that a satellite phone is all you need, can some one explain the pros and cons
Joe, I'm totally biased of course, never having used a sat phone, but I wrote some notes on the benefits of HF radio in a recent newsletter , page 6.
Ignoring the obvious phone/HF radio physical differences, the deciding factor for me is the the ability to contact many, rather than just one listener. If I had a real emergency I would want as many people to know about it as possible, and help (certainly advice) might be just around the corner.
Atmospheric conditions do sometimes makes radio communications difficult, but I've also seen sat phone users experience difficulties in making satellite contact. So an EPIRB is essential too.
Thanks, I've got a 6 metre telescopic pole and several antenna tuners (one with built in balun), plenty of wire and a Terlin multi-tap antenna to chose from for my plan 'b' antenna. I'll also have a coax fed balun/long wire antenna to chose from if it arrives in time.
Most non ham HF sets don't have built in antenna tuners so I'd expect a pretty ordinary match with a long wire on the ground/bush/tree and I'm a bit leery of 100 watts of RF just 'lying around' so to speak. But certainly better than nothing in an emergency and quite fine for receiving.
As for the auto tune Codan 9350 antenna, a SWR of 1.2:1 on 8022 kHz which I thought was OK when mounted on the front of the OKA.
Joe, if you've got the Codan (which model ?) it certainly won't hurt to install and where as the sat phone lets you talk to one person at a time (if you know who to ring and have the number), the HF allows greater interaction with other travellers and base stations as well as weather/road reports. VKS 737 is also able to pass along messages. As long the HF has 8022 & 5455 kHz it'll be fine.
Dean and Kaye Howells wrote: Joe, as long the HF has 8022 & 5455 kHz it'll be fine.
Joe, most old Codans don't have VKS channel frequencies fitted but they can usually be modified, depending on the model (6801, 7727, 8727's are OK and are quite reliable). I've upgraded several Codans to include 5455 and 8022 khz (the primary VKS channels 1 and 2) and also fitted selcall microphones so they have all the current emergency features required.
If you are interested in going that way, I can certainly help.
Regards,
Dean and Kaye Howells wrote: As for the auto tune Codan 9350 antenna, a SWR of 1.2:1 on 8022 kHz which I thought was OK when mounted on the front of the OKA.
Deano, if you can achieve an SWR of 2 or less when mounted on the rear you doing OK (less than 10% power loss). Above 2 to 2.5 and you are losing 20-25% or more of your transmit power , 3 or higher is bad.
An insulated antenna lying on the ground is OK as long as no one touches it while actually transmitting (talking). The same applies to any antennae mounted on a bullbar. Not likely to be fatal but could deliver a mild shock.
- OKA 138
We also have a sat phone but as the VKS network handle all the RFDS radio traffic it made sense to go the radio way again , with the numbers of people now using the VKS network help could be only a few minutes away which wouldn't happen with a sat phone unless you had their number.
We still use the sat phone but mainly for keeping in touch with the family.
I'm just deciding which radio network to go with at the moment and trying to decide between VKS and HF Radio Club. I'll do a bit more research and go from there.
Cheers again!
Alister
Listening in doesn't require membership but transmitting does (membership covers licence fees). You might consider joining both clubs for a year ($110+ pa each). Pro rata is less, right now you could join both for the rest of this year for $50-65 each before deciding which one to stick with. Check that your radio (and antenna) can access their main frequencies before joining.
A useful list of frequencies for all HF radio clubs is here .
Note, for anyone whose radio doesn't have selcall facilities (needed these days to contact the RFDS/base operators by radio), there are now apps for iPhone, Android, Mac and PC computers to generate (but not decode) selcall tones. See this site for details. You key in the required selcall number, press the radio mike PTT button and hold it near the phone/computer speaker. Cheap and useful in an emergency. Once contact has been established, radio comms takes over as normal.
Selcall app update: See this VKS document .
