Sun visor air dam drag
- Hal Harvey
14 May 2014 22:10 #41
by Hal Harvey
Hal Harvey replied the topic: Sun visor air dam drag
It's all bad news on the drag-racing-in-OKAs front, I'm sorry to say. We finally got a fine Wednesday night coupled with reasonable health, the OKA was ready to go, I had all the gear and I fronted up at the required time. But I didn't get any further than the queue for safety scrutineering. A fella with a clipboard came over and said, "I think you're going to be too tall".
Que? What difference could the height of the vehicle possibly make, I wondered (not out loud). Not the vehicle. He elaborated: there's a rule somewhere that says the centreline of the crankshaft can't be more than 600mm off the ground - thinking safety and stability at speed. He even had a tape measure. It was a bit of a giveaway that he barely had to bend down to measure it - 750mm. Sorry sir, but there's no way you can race this vehicle as it is.
And realistically, I'm not about to change it so that I can. So you won't see #260 on a drag strip, I expect. A disappointing result, tonight.
It looks like my only prospect of getting genuine times is to use my mate's PerformanceBox and a long length of safe private road. I don't know when that will be.
15 May 2014 05:13 #42
Peter and Sandra OKA 374 replied the topic: Sun visor air dam drag
There's got to be someone around with some wheels with low profile tyres in our stud pattern.
Oka on slicks!!
Oka on slicks!!
15 May 2014 06:54 - 15 May 2014 06:55 #43
by outyonda
outyonda replied the topic: Sun visor air dam drag
The I must be mad post, there is a pic of tyres.
the rims & tyres on the left are ex ambo
measured against 19.5, 140mm difference
put them on front, half flat & 19.5 305 on rear or 16 x 325 should get under 600mm
or low profile tyres on those skinny rims!!
Last Edit: 15 May 2014 06:55 by outyonda.
- DarrenWebster303
15 May 2014 17:43 - 15 May 2014 17:46 #44
by DarrenWebster303
DarrenWebster303 replied the topic: Sun visor air dam drag
Oh mate, I feel so sorry for all your effort. Im sure a regional 1/8th mile venue will not be a problem, if you can be bothered. Its an easy, accurate calculation from 1/8th to 1/4 & a lot less chance of the sun-visor (nice segue way back on topic huh) peeling the roof off 260 at the finish line too.
Last Edit: 15 May 2014 17:46 by DarrenWebster303. Reason: wrong build number
