Zone RV
04 Nov 2015 12:42 - 04 Nov 2015 12:43 #1
by PeteFox
PeteFox created the topic: Zone RV
Dont I just wish this was available before I started my build
Build yourself caravan kit
I'm sure they would modify for a motorhome on an Oka, note the video shows a slide out bed as well
Last Edit: 04 Nov 2015 12:43 by PeteFox.
The following user(s) said Thank You: Dean and Kaye Howells, Paul Scherek
04 Nov 2015 17:19 #2
by Peter_n_Margaret
Peter_n_Margaret replied the topic: Zone RV
The same or similar material I used for the camper body for #196 11 years ago.
vanglass.homestead.com/
Very easy to use.
I don't like the aluminium corner extrusion though because it has an outside to inside 'cold connection' that would cause severe condensation in cold conditions.
Very easy to use.
- Garry and Chris
08 Nov 2015 08:47 #3
by Garry and Chris
OKA 306
Garry and Chris replied the topic: Zone RV
Can't imagine it on corros
OKA 306
08 Nov 2015 16:00 #4
by Paul Scherek
Paul Scherek replied the topic: Zone RV
It hangs in pretty well. I used no frame at all, just composite panels glued with angle aluminium along the edges inside and out. Last trip was pretty corrugated - ripped out the rear shocker mounts from the chassis, but the panels and camper are still fine.
The panels don't fatigue much with flexing, are very strong and give good thermal insulation. They are also even lighter than steel.......
