Aluminium bull bar
- Harry
has anyone had one made from anywhere ?? Oka's are high enough of the ground , and most vehicles and trucks run Alliminium ???
I am thinking about ringing Mr. Bull bar of Wagga Wagga ...
I've discussed that same question with a mate who has spent most of his life running an alloy and stainless manufacturing business, his view was that by the time you made the alloy bar to be a strong and durable as the steel version there wasn't much weight saving as such especially with the Oka's need to make the ends very strong so as to be used for the access step.
The centre support section for those with a winch would need to be steel for strength purposes, in fact lots of alloy bullbars are built that way with the bar actually being a "cosmetic" add on.
A good nerf with an alloy bar usually means total replacement as they stretch readily under impact and don't spring back but stay deformed.
- Harry
- Peter334
- 210greg
- Harry
Ditto.Peter334 wrote: My winch is not at any way attached to the bull bar, it is fitted to the chassie of the vehical, so I pull the chassie and not from the bull bar................
In fact, I cut out the centre 4-500mm of the bumper bar completely.
#196 does not have a bull bar. The bumper is high enough that I don't see much value. The couple of roos that I have hit have gone underneath.
moral of story, we continued on slightly bent bit still going
bar was a write off
the alloy bars are
a one hit wonder, even on trucks not many survive A bull
there is a few with steal bumper & bolt on alloy pipework.
We've had a few near misses with camels. This well camouflaged specimen darted out from behind some bushes on the Great Central Road. We missed by only a couple of seconds and hitting a tonne of camel would have been a potential disaster.
- DarrenWebster303
The Ann Beadell & Canning were quite sporting, dodging them a few years back. Keep the steel one Harry for what it weighs in my opinion.
- Harry
Thanks again guys happy travels and stay healthy
On the note of aluminium v steel, in general, steel is twice as strong and weighs 3 times as much so an equivalently strong aluminium object made just as strong should weigh 2/3 as much. Please note, these details are generalisations and in fact if you get 7075 T6 grade aluminium for example you're looking at a metal nearly twice as strong as mild steel and weighs a third of the weight, so not all aluminiums are the cheap supermarket type you get at every corner store...
My 2 bobs worth... once again.
Cheers, alister
