Fuel Filter
- 210greg
07 Aug 2016 04:53 #1
by 210greg
210greg created the topic: Fuel Filter
No forward momentum. Returning home after a quick 2000 k trip all on black top when everything ground to a halt no go. Lifted the lid and to my surprise some little thief had stolen my fuel filter. No problem I have a spare but what I did not have was the glass and the bottom bolt to screw it together. The filter was due for replacement so had been to Birdsville and back. So my questions are 1/ has this happened to anyone else 2/ how do we prevent this happening again. 3/ can I buy the glass and bolt anywhere or is it special (like me) Any suggestions please.
07 Aug 2016 06:41 #2
Peter and Sandra OKA 374 replied the topic: Fuel Filter
It's a standard CAV part Greg so should be available anywhere that sells tractor or truck parts. You would probably get a secondhand one at truck wreckers too. You can buy a brand new whole assembly from Whitworths online or instore they were under a $100 last time I looked.
- John and Bronwyn
07 Aug 2016 06:44 #3
by John and Bronwyn
John and Bronwyn replied the topic: Fuel Filter
No, I haven't had it happen to me but I have seen it on parked machinery.
The primary fuel filter on 191 is a standard common "CAV" type. Doubt you will get just the glass & bolt, you will probably need to buy the whole unit. Many 4WD outlets have them.
Re prevention.... Some sort of locking device to prevent access?
07 Aug 2016 08:39 #4
by Outback Jack
Outback Jack replied the topic: Fuel Filter
You sure it was stolen? Not fallen off??
I have had in the past had the bolt come loose and the bowl etc come off.
169 had filters and bowls bolted to battery tray. Not sure if Rob has changed it, but I never had a problem with theft.
07 Aug 2016 09:13 #5
by Ralley
Ralley replied the topic: Fuel Filter
Hi Greg I can help you send me a message and I'll see what I can find.
- 210greg
07 Aug 2016 15:04 #6
by 210greg
210greg replied the topic: Fuel Filter
Unless he was really quick it was not stolen as I was in Angel mode ( Down hill doin 105) and it must of just fell off. I was thinkin it might have Murphy. Thanks for the support.
07 Aug 2016 16:21 #7
by Ralley
Greg I had a look and I have one, if you would like it you need to let me know because I head of on my next trip on Tuesday.
- 210greg
09 Aug 2016 13:26 #8
by 210greg
$65 for complete unit. Still cant believe it fell off ( Should we carry one as spare )
- OKA 138
09 Aug 2016 17:03 #9
by OKA 138
OKA 138 replied the topic: Fuel Filter
Greg the glass water trap probably cracked which can happen if it is overtightened or fatigued with age ,you can get one with an aluminium bowl instead of glass I use that one and I have fitted spin on filters with water drain screws and they act as primary filters [one on each tank] so you don't need a water trap on the CAV Filter.
