Select ing low range
- 210greg
02 Nov 2016 08:50 #1
by 210greg
210greg created the topic: Select ing low range
Dean is having an issue with 366 in that. started being difficult to get out of low range now cant seem to engage low range? Is a cable set up standard in LT or is his special?
02 Nov 2016 09:07 #2
by mort
mort replied the topic: Select ing low range
Hi Greg I have the Rockwell which has 2 cables and while stationary it is difficult to engage or disengage the vehicle has to be moving other than that it may be cable adjustment.
Martyn "its an OKA thing"
02 Nov 2016 14:26 #3
Peter and Sandra OKA 374 replied the topic: Select ing low range
Greg the shift shafts and pivots where the cables attach can get gunked up with dirt and crud which can make them very stiff, try degreasing the area and hosing it all off and you may find it fixes it.
02 Nov 2016 15:48 #4
by Outback Jack
Outback Jack replied the topic: Select ing low range
I have similar problems with my LT. When I spoke to Al about this he said that LT need to be slightly moving to change over.... But not sure if that is the case
02 Nov 2016 17:33 #5
by Joseph Baz
Joseph Baz replied the topic: Select ing low range
Greg,getting out of low range is a common problem with some heavy boxes,best to try to reverse a little while trying to disengage,as Peter said the cables may be dry and covered in crude but Rockwell's are better at changing on the move (not at speed)
02 Nov 2016 20:58 #6
by mort
Greg I have just looked up the instructions for the rockwell.
engine rpm to be less than 1200 and vehicle to be moving at no more than a walking pace.
The following user(s) said Thank You: OKAPETE
