CSR Permit
- packhorse
I intend to travel alone, South to North in July without deviation.
So, does anyone have any recent first hand experience on dealing with this situation or the ramifications on ignorance?
Mick
- nugget
They also * trailers but they don't refuse the permit fee on those either.
Pity we will not catch up on the track.
That was always the case back in the 90's and into the 20's as that section utilises station tracks and the properties wouldn't allow larger vehicles on their tracks, as I said I've no knowledge of current restrictions if any.
Given that there are commercial groups using 6wd Mercedes it may not be the case anymore. As it says on the permit page best contact the stations involved before you head out.
- nugget
At that point you enter Cunyu Station and have to obey the follow rules.
I would argue the OKA is not a wide track vehicle but if worse came to worse, they give the alternatives. Generally if people are reasonable, doing the right things and not being idiots, the station people are pretty reasonable. Missing the last couple of wells is hardly a train smash as the if that is what it came to. Be more than happy to have done the rest.
As it was we didn't have permission to travel through Glen Ayle until we left Durba after a lengthy RFDS discussion (no satphones then!) with the Wards on Glen Ayle as their country and tracks were also under water at the time but we were given the ok as long as there was no further rain. They also realised that once we left Durba we couldn't turn around as we wouldn't have enough fuel.
The western end of the Gunbarrel into Wiluna was also closed due to flooding so we had to refuel at Carnegie and then head south down to Sandstone and then down to Leonora. We were the first on that section of road for several months as well, some of the washaways were deeper than the troopy was high and mates travelling behind reckoned we disappeared out of sight in some of them.
I've not looked at rainfall maps but that last cyclone might have dampened some of it a bit.
We still reckon the CSR was one of the best trips we ever did and having been back across bits of it since we're glad we did it back then before it became a corrugated track with endless traffic. At times we drove through 2m high spinifex for days due to the lack of traffic for several months after the rain and with lots of water around it was pretty special with most lakes and claypans having some moisture with the associated explosion of wildlife.
We still haven't been south of well 9 though and probably never will with the Oka not being allowed on that section. below 5.
No permits or fees back then either, no signage except the Gards markers at each well and I would recommend getting a copy of the Gard's book on the stock route as it has a wealth of info and history as well as strip maps of each section.
The Canning Stock Route A Travellers Guide by Ronelle and Eric Garde, we had the first edition as it had just come out at the time but it has been out of print for a while I think it might still be available either secondhand. or it might have been reprinted at one stage.
The only maps in those days were their strip maps and the Australian Geographic Map which was one of the first they did so we navigated with a single channel GPS and lots of 1:25k topo maps if we had to make detours around flooded sections.
nugget wrote: The permits only cover to well 5.
Cunyu station has new owners now, the bloke that was a P I A is long gone, the sign stands & OKA's are fine, I have been through there several times with both owners .
Respect, contact the station.
The Canning Stok Route is A public access STOK ROUTE, 50 miles wide, the permits are free !!
There was a project run back in the early 90's to actually get the vehicle track back on the actual CSR reserve but as it relied on travellers/volunteers to drag a steel frame to knock the worst of the bumps off and then following traffic to establish the "new" route it didn't work very well. A few short changes were established and form part of the current track but not enough to miss the native title lands.
He was (is) basically one of those eccentric FIGJAM types that bent the rules for his own power appetite and didn't understand the difference between a pastoral lease with obligations in maintaining CSR access and freehold land. He used to have all these silly signs up saying no night time travel, no large vehicles, no trailers etc and got away with it for years. Hated OKA's with a passion. Don't even go into the desecration and moving of the original station buildings etc. His loss (hopefully) will be a boon to any and all 4WD access on the CSR.
Originally CSR 'permits' were managed by a mob called 4WD Australia or something similar which was really nothing but a group of two or three blokes working out of Sydney I think. Basically a money making scam with their 'Group' now basically disowned by the legit 4WD movement. All very complex.
No idea where it all stands today with all this native title 'opportunism' going on but you can bet your boots that if there's a quid in it 'white fella' lawyers will be as thick as fleas on a dogs carcass bleeding the system for all it's worth.
If it means a quid and opportunity for the local communities then I'm all for it but am cynical as to who will come out on top here.
If Cunya Ken has 'moved on' then IMO it can only be a good thing for CSR travelers in the future.
- nugget
Generally experience has been that permits never get checked. One trip I required 19 permits and never checked.... not once. Might be different in the OKA..the big bluey is probably a bit harder to miss than a white 130
Let you know how we go end of June some time.
Give a hoy if you come through the centre.
We spoke to a retired WA government chief surveyor and he was quite scathing og lease holders who pretended legal rights they didn't have because conditions of their lease only applied to grazing rights, not total access for other reasons.
"Generally experience has been that permits never get checked. One trip I required 19 permits and never checked.... not once. Might be"
Not to be counted on in SA parks though. One yobbo in our group was mouthing off on the radio about lack of passes and pretty soon we were stopped by rangers and all vehicles were checked.
- nugget
It really doesn't matter but I must admit I get a bit pee'd off being made to often jump through hoops, pay extortion fees...like $350 for the CSR....and then no bludger can be bothered checking. Whilst I am happy not to be harassed, still feel a bit ripped off I must admit.
When I plan TREK's I spend hours on PH talking to Stations for permission & RESPECT, [ even Cunya Ken ]
I like to know who is going through my back yard !!
Permits are ONE call to Aboriginal Land Councel;: cost free permits all states.
- nugget
Hay River Road, at least one Survey peg are serious money. And of course Canning Stock Route.
- nugget
- travisg
travisg wrote: ive done the complete Csr 18 times so far, only once in a car, the rest in over 4500kg stuff. I never had a problem after a few chats to the landholders and only attempting it in dry conditions. ive eels helped with well reconstruction etc which allowed a few groups to see that a truck can do less damage than a car if driven correctly and carry equipment safely. as long as you get you tyre pressure right for the dunes you can walk up them especially with the wombat holes others leave!
What pressures are you running?
(And what size tyres?)
- travisg
travisg wrote: Each times it’s been. Bit different, however no matter how low I’ve gone I have never de beaded a Tyre and I go way below what many people recommend. It’s. Balancing act going low without too much exposure of side walls. I normally run about 40 psi from well 1 to 10 and then drop to around 20. From there if I don’t feel i’m Getting enough tracking i’ll Drop 2psi until I find the sweet spot that I can be in first gear high range and just walk it up without working to hard but in the sweet spot for revs
So somewhere in the 13-20 psi range?
I am running 255/100 16 (XZL).
I assume that this would apply to me too?
Or what tyres are you running?
(And is more tread-width needed for the CSR?)
