OKA 413 _ A New Hope
As discussed earlier I replaced the factory H1C turbo with an upgraded HX35 (non waste-gated) turbo. This improved performance marginally and was a simple bolt in, same overall dimensions replacement. The only appreciable benefit here was an improved design, more robust and newer turbo but not a significant performance increase (without re-tuning) .
Since my last post I've obtained a suitable HX35W (wastegated) turbo which is marginally longer than the existing non waste-gated version so is not a direct 'drop in' replacement. Some exhaust modification is required, not hard but fiddly and should make a significant difference, when tuned correctly, particularly in lowering EGT's I'm hoping.
The waste gated HX35W is at the top of the picture with the (Cummins 6BT) factory H1C underneath. Inlet dimension (3") and mounting position/flange are the same but the added waste gate lengthens the turbo by approx. 35mm which means modifying the exhaust plumbing accordingly.
Choosing the 'right' HX35W can be a bit daunting as this is a generic designation covering many turbos for many applications. To make it more confusing identical turbos can have different part numbers. I confined my choice to genuine Holset HX35W's that were originally intended for Cummins 6 cylinder diesel engines and not cheap 'knock offs' which abound in the after market/eBay world. I spoke with other Cummins Oka owners to see what they were using and ended up with this one.
All genuine Holset turbos have a manafacturers plate like this attached. The number at the top, in my case 4042738 identifys this particular turbo. A site such as this can give additional information to help in selection.
Turbo Specifications
eg. This informs me that this turbo was originally intended for a 2005-2012 Cummins ISB 5.9 litre 6 cylinder diesel engine (a newer version of my Cummins 6BT engine). It also tells me that equivalent part numbers are 4039508, 4043248 and the OE or original equipment Cummins part number is 4955174. Other details include turbine and compressor impeller sizes, part numbers etc.
Deciding on a particular turbo spec. is the first part of the journey the next part is to buy OE or after market, I decided on OE as I'm a bit wary of the cheap after market turbos out there, some of them may be quite good but I don't have the expertise to pick the good from the bad so stick with OE for known good quality though to be fair there are after market turbos out there that have better than original components but these are definitely not the 'cheapies' on eBay.
This bloke has some pretty good first hand information when selecting a turbo
eBay vs genuine Holset HX35 turbo
The next step is to source your turbo of choice, this is where it's real handy to have the equivalent part numbers as this is what defines the actual turbo. and how it is advertised.
There's three different 'types' of genuine turbo out there, new, used and 'new - dismantled'. There's a specific 3 letter acronym for this used on US sites that I can't remember but essentially what it means is that (for example) a new crate engine has been dis-assembled and the parts sold off separately. This can return the vendor a better return when buying up NOS (new old stock) and on selling.
This is what I bought earlier this year.
Holset HX35 turbo
It cost me $424 at the time. All up cost was $642 including air freight from Hong Kong and GST/import costs which I thought was pretty good.
So far, so good .............................. now all I have to do is get it installed
For those not into it, basically there's two variants, air to air and water to air inter-cooling and it's all about decreasing the temperature (and increasing the density) of engine intake air. With air-air inter-cooling air flow is used to directly cool the engine intake air basically by passing intake air through a large radiator in a similar fashion to an engines coolant and is the most common method used.
Here's a shamelessly stolen photo of Nuggets Oka 224 showing its air to air intercooler, a comparatively easy fit in an XT compared to an LT which had its radiator much further forward.
With water-air inter-cooling (sometimes referred to as after-cooling) a separate 'heat exchanger' system is used to transfer heat from the engine intake air to a coolant and then remove this heat via a radiator. There are two variations that I know of to this method. One system that was originally used by Cummins had the inter-cooler mounted on top of the engine and used the existing engine coolant to absorb heat removed from the intake air. eg. The A in Cummins 6BT-A refers to 'after-cooled' and is a very simple and relatively cheap method of inter-cooling though not particularly efficient as the air coolant temperature is engine coolant temperature.This system was designed primarily to allow for cleaner less polluting combustion.
Cummins 6BT A showing its water to air intercooler directly mounted on top of the inlet manifold.
The more common method of water to air or W2A inter-cooling is to run a separate closed system (the same as an air conditioning system) that has its own separate inter-cooler, radiator, fan, water pump and coolant and is the method I have chosen primarily as any failure or damage to the W2A system does not impact on the existing engine or air intake integrity. Generally, it should be hell of a lot easier to install a W2A system such as this in a LT Oka than a comparable air to air system, at least I hope it is. There might be more components (and cost) but IMO running 19mm heater hose is lots easier and potentially more reliable than a connecting a dozen or more metal pipes, silicon bends, clamps and bracketry together. If building a vehicle up or for a partially dis-assembled vehicle it might be a different story. Fitting a 75mm (or more) thick air to air inter-cooler between the air con 'radiator' and the engine radiator in a LT can also be quite 'challenging'. Basically my reason for going W2A is simplicity and reliability.
Here's the main components.
On the left is a 600mm X 300mm X 25mm aluminium radiator with the W2A inter-cooler on the right. The inter-cooler is basically 300mm square and 100mm thick with 76mm inlet/outlets. Both were bought 'second hand', the radiator quite cheap because two side fixing lugs (which I don't need) have been broken off and the inter-cooler (imported from the US) and brand new for a project that didn't get off the ground. $200 the pair which I thought was pretty good
I've yet to source an electric fan(s), water pump, remote filler neck/expansion tank hoses, barbs etc.but at least I can get a wriggle on installing these two main components.
The inter-cooler will mount here
The existing air inlet 'cross over' pipe will be going and the rear mounted coolant catch tank may need to be moved to the left. A new inlet manifold flange plate with 76mm hole is on order and will bolt straight on top of the inlet manifold where the cross over pipe went and connect with a simple 90 degree bend to the inter-cooler (blue arrow). The inter-cooler (hot) air inlet path, red arrow, from the turbo outlet is as shown.
The inter-cooler radiator will mount here.
It's actually easier to mount it here under the cabin floor and just above the bash plate than in front of the existing radiator and it doesn't interfere with the existing airflow or require grille or other modification. A couple of simple mounting brackets and some air vents cut into the bash plate and there you go
All I need is the time ...................................
Please amend Martyn if you could as I can no longer edit my post.
Thanks Deano
- nugget
ps. You bloody banana benders will NEVER be forgiven for stealing "The Greatest Show on Earth", but if the "boys from old Fitzroy" win it won't be all bad
The radiator was fiddly to fit due mainly to the size (600x300x25) and the necessity to clear a/. the drag link, b/. the radiator return pipe, c./ the bash plate as well as being vertical and in an unobstructed air path. A 500x250 radiator would have been a LOT easier to fit.
It ended up looking like this.
The bash plate rear mount will be 'dropped' by about 40mm so that the bash plate clears the bottom of the radiator by 10mm or so. Originally the rear of the bash plate stops just above the tie rod leaving it unprotected so dropping it by 40mm will give the tie rod some protection
Next I'll cut some shallow U shape 'louvres' into the bash plate and bend them up to horizontal to direct air flow onto the radiator.
For additional cooling I'll add a 12" electric fan (with a suitable controller) to the radiator. I've got a pair of these but reckon one should do the job. I picked these up fairly cheaply ($25 the pair) from a 'bloke up the road' who had them on his 4 litre Jaguar. They're Davies Craig 12 volt/130 watt fans and are fairly generic and readily available.
Sorting out the electric fan has been an interesting exercise. What I thought would be a pretty straight forward job was a bit more complex than I expected.
Here's a pic of one of the fans (they're both the same). Note the attached air flow sticker. More on the concave annotation later.
When I got these fans the backs of the fan(s) looked like this.
Which, when reading the 'must face front of vehicle' instruction would tend you to think the fan mounted on the back of the radiator but contradicts the direction of air flow sticker as you're hardly likely to put the fan behind the radiator and blow air forward
against the natural air flow of the moving vehicle. The fan also rotated in the opposite direction to the arrow shown. The fan operated OK but airflow was less than I expected.
Whilst the direction of rotation can be changed quite easily by reversing battery polarity on the +ve and -ve leads to the fan motor it just didn't make sense to do so. The motor has a red and a black wire which pretty well tells the way it's supposed to be connected. Hmmm .................... there's something not quite right here. I removed the fan blade and found this.
The fog started to lift and things became clearer, the fan blade assembly had been installed backwards on both fans and by the look of it from new. This is actually a pusher fan(s) that goes on the front of the radiator. With the fan blades installed the right way round the direction of flow sticker is now correct, the face rear of vehicle instruction is correct as is the direction of rotation arrow. The airflow volume is significantly greater, so a tick in every box
What I couldn't figure out was how come the airflow had increased so dramatically as the fan pitch and direction is the same no matter which way the fan rotates or is mounted and its mounting is symmetrical so how come the face forward/face rear instruction ?
Here's a closer look at the other (leading) side of the fan, ie. the side that should be facing the incoming air.
What surprised me here is that the curve of the blade (as opposed to the pitch) has such a significant effect on airflow. For this fan to work effectively the convex side of the blades must face the incoming air with the concave side towards the outgoing airflow.
This is probably simple 'Aerodynamics 101' but it was news to me. You're never too old to learn
Just wondering, (i'm sure you thought about this!) why were you concerned about having the IC rad vertical? It could be horizontal if you wanted it to... Best rad design incorporates a bit of forward 'lean' so the heating effect of the airflow going through the rad is helped 'up' and out of the rad core etc. Might have made the packaging a bit simpler? As i said, you may have thought of this...
cheers, al
I suspect you're right with the wing analogy but not really my field
As for leaning the radiator forward, yes it would have made installation easier and may well have given a bit of bias to outgoing airflow but my concern was that natural airflow through the radiator would be decreased as the cooling fins could act as a barrier to the airflow. I recall that Peter James mentioned some time ago that his Hummer had an angled radiator with the cooling fins/tubes angled so that airflow remained unimpeded.
If fan blown airflow was to be my primary cooling method I could have mounted the radiator at any angle and used both fans to achieve this. For natural airflow to be effective I figured the radiator cooling fins need to be in line with the airflow and not angled as this would impede the natural flow of air. I did consider angling the radiator forward and angling the louvres in the bash plate to be perpendicular to the radiator but decided not to as keeping the louvres horizontal should
So basically it came down to this, a vertical radiator with natural airflow and one part time 'assist' fan or an angled radiator with two fans with one or both operating continually depending on load. I went with the KISS method for reliability/efficency. Another consideration was electrical load from the fan motors. Each fan motor is 130 watt, 260 watts for the pair or around 25 amps at 12 volts so significant considering my alternator is a nominal 85 amp generic Bosch.
There's the reasoning for the direction I've gone, all good in theory, now for the practice
Honestly it's hard to say which direction airflow is travelling on a vehicle without testing, but either way, with how little heat needs dissipating with an IC i don't think you'll have a problem, and what's more your setup looks good... and a lot more complete than mine for the moment!
I bought a brand new Cummins/AC Delco 160 amp alternator that fitted straight on the 6bt that put out 100 amps at idle which solved the problem.
There is a bloke on ebay that sells them regularly as they upgrade gensets to 250 or 350 amp ones and he sells the unused 160 amp ones for around $60 US.
Rob Alley has a 250 amp version on his Oka. The model number of mine is a 24Si and the larger one is a 28Si I think.
Yeah i think Icarus mentioned it on page 3 or 4.
I'll see if I can search the tablet.
Yeah i think Icarus mentioned it ......................
I think his failure was due more to Thermodynamics than Aerodynamics
I think his failure was due more to Thermodynamics than Aerodynamics, I'll be taking a more cautious approach
Hence no Aero 102 made it to a tablet.
That was all wright
Just something to think about.
In the mean time I figured cooling the input air should make a significant difference to EGT's and it is my motivation for going down the inter-cooling path. I didn't go into any sort of scientific dimensioning for the inter-cooler radiator, basically this one came up for $50 and it fits so I decided to give it a crack
My Davies-Craig fan controller can handle two fans and comes with a temperature probe which I've installed into the bottom tank as I figured the return coolant temp is more important than the 'hot' side. I figured one of these would be a good idea to gauge what exactly is going on
Prosport dual temp gauge
I'll keep plugging away and thanks again Rob for your input it's much appreciated.
Dean and Kaye Howells wrote: ... #413 was 'recently' tuned by AG Diesel here in Melbourne with the priority's being reliability and efficiency. ...
How much did the efficiency improve?
What litres/100 is it doing now?
It depends on how you define efficiency really, the improvement in performance and ease of driving was marked. A much easier and more pleasant vehicle to drive now. The obvious technical change was the high speed AFR across the 'power range' say 1800 - 2100 rpm was improved from around 25:1 to around 22:1 which is the actual sweet spot for this type of engine. Cruising EGT's dropped a fraction say 40 C maybe. Fuel consumption is basically unaltered from around 16l/100 k's for my 'normal' driving. ie. highway cruising at 92-95 kph which was the same with the Perkins.
Easier and less tiring to drive, fewer gear changes makes the Oka experience more 'comfortable'. So I guess the efficiency improvement is more power and less gear changes whilst holding the same speed for longer with the same fuel consumption.
The real lesson out of this was to get the engine properly tuned by someone who knows what they're doing.
Thanks.
I say that the tuning goals were "efficiency and reliability"... but usually power wins in most cases.
And the ease of driving was not a goal.p... which is usually what is many people goals.
With plans for a much anticipated 2021 Okaing adventure time was short for planned maintenance including a new crankshaft/timing cover seal, turbo and transfer case upgrade, engine driven compressor install and general 'smarten up' of #413 which was looking a bit shabby after many years of hard work and being kept in the open.
Fortunately Ian Jones had an opening in his schedule and #413 was booked in
Timing cover / crankshaft seal
A word of advice here. NEVER, EVER buy parts from Cummins Australia unless your life depends on it as they are absolute unconscionable thieves. A simple timing cover/crankshaft seal kit was $260 and it didn't even come with the required insertion tool (very important for the double lipped seal to avoid damage when installing). Probably so that they can sell you additional seals and further rip you off. I kid you not, avoid Cummins Australia like the plague.
A quality aftermarket OEM kit including insertion tool costs less than $50 in Australia or genuine Cummins from China (eBay) for around $26.
Holset Turbo HX-35 W (4042738)
The never ending (turbo upgrade) story
The Cummins 6BT in #413 originally had a Holset H1C non waste gated turbo which I'd upgraded to the later HX35 non waste gated turbo. With a view to even better efficiency and more low down power I obtained a HX35W waste gated turbo to suit this engine. Unfortunately this is not a simple 'drop in' replacement as the exhaust needs to be modified as the HX35W is approx. 35mm longer than the H1C/HX35. The waste gate actuator arm also needed to be moved to clear the chassis rail, not a big deal but needs to be done carefully to maintain correct alignment between the waste gate actuator and the rest of the turbo body. At the same time I fitted an adjustable boost controller to simplify 'tuning' of the waste gate.
Engine driven compressor / hydraulic pump upgrade
Fortunately the Cummins 6BT has the option of mounting a (timing) gear driven compressor on the rear of the timing cover between the timing cover and the hydraulic pump. Air is drawn from the inlet manifold into the compressor which has an automatic 'lifter' tied back to the main air reservoir so that is cuts out at a pre selected pressure and doesn't continually pump air when not required. This entailed the provision of a Knorr Bremse air cooled compressor and a replacement ZF hydraulic pump to suit.
The air tank is mounted at the rear of the Oka above the spare wheel.
Armoured teflon air hose from compressor on the left via pressure relief valve to tank. Output on the right (blue hose) to Nitto fitting on LHS of vehicle with 6mm (black hose) to compressor 'lifter' and dash mounted gauge.
Next up ............................. transfer case upgrade.
Well, this has been a long time coming. #413 is one of several LT Okas fitted with the NT transfer case also known as the HD150 as in heavy duty 150 (I'm told that the 150 refers to its weight in Kg and although I haven't weighed it I'd believe it. It's VERY heavy.
This transfer case is a monster of a thing and hangs down lower than the LT's usual Rockwell TC or the XT's NP205. As far as I can tell the TC was designed and manufactured by Reumech for the South African 'Casspir' armoured vehicle. Reumech eventually became Vickers / Alvis / BAE / Land Systems and is currently owned by Denel Mechem (South African government) who now manufacture an upgraded Casspir NG2000 'mine resistant' (as in mines that go bang) armoured vehicle.
The HD150 has the same basic three shaft 'cloverleaf' design as the Rockwell and as such is not particularly efficient (power wise) though it does have helical cut gears and doubled up bearings unlike the Rockwell. Running SAE30 lubricant it doesn't run as hot as the Rockwell (though hotter than a NP205) and has given us years of fault free service. It even has a reliable hand brake unlike many Okas
Here it is, above, in all its 150 Kg glory complete with LT mounting spine and bracket.
So why change it ?, weight saving of around 75 kg and the better power efficiency of a more modern simple design (2 shafts vs 3) and a strong reputation for reliability with parts availability and rebuild expertise Australia wide.
The replacement transfer case came from an ex RAAF Acco which had only done around 30,000 Km choofing around RAAF Base Williamtown.
It already has a 29 spline input shaft so I added an upgraded heavy duty output shaft and bearings etc. when rebuilding so is hopefully better than new
Replacing the transfer case was not just a simple matter of "out with the old and in with the new". There's actually a bit of re-engineering work involved to ensure that suitable drive line angles are maintained. This involved lots of angle measurement, adjustment of mounts and the fitting of rear axle housing wedges. A new transfer case mounting spine and bracket was also fabricated. Fortunately Ian Jones has done this upgrade many times so has the correct jigs etc to make the job a lot easier
The end result looks like this
Input/output flanges were changed to take 1410 universal joints with U bolts replacing the factory Dana 'straps', including on the jack shaft. Note the 'elevated' oil filler in the second photo.
Rear axle wedges and longer U bolts were needed to tilt the axle housing so that drive line geometry could be optimised for the NP205 whose output shaft comes out higher than the old 'cloverleaf' transfer case it replaces.
Both front and rear drive shafts were lengthened/shortened to suit the new installation.
I decided to keep the original Acco hand brake assembly as it seems to work just fine though I was tempted to fit Paul Nott's disk brake hand brake which is much better, Where do you start and where do you stop ? Last time I looked this was around a $2K upgrade and well worth it to upgrade a crappy failed Oka factory hand brake but while mine's OK I'll let sleeping dogs lie.
Here's a pic of Rob Alleys disc handbrake I filched from another post, very neat and professional and much more efficient than the factory offering.
