Icy OKA
woke up to 30+cms fresh powder this morning
have had a few mornings around -8 degrees
first morning...
motor home water pump frozen (so no water hot or cold)
sink drain frozen (sink soon filled with scrounged water, moral ...don't even bother to make a cuppa using water out of hot water bottle! yecht!)
water in air step condenser frozen (so no air step)
wiper washers frozen
had to wait for interminable minutes for the Perk to fire after belching plumes of steam and smoke
simple answers...
keep diesel heater running all night at 5 degrees to stop pump and drain from freezing
in the morning boil kettle, pour a little on ...
the air step condenser
the wiper washer pump
and then the rest over the inlet manifold, intercooler to manifold piping, the injectors, injector pump, filter and all diesel lines.
Perk starts first kick
Simples
I've hooked up the Webasto Thermotop to the engine cooling system so that in the future it might start easier when cold. Ours being a genset engine doesn't have an intake heater.
Turning the diesel air heater on at around the 2am "pee" time and running it on a low setting makes things much more livable.
Do you sleep with the poptop down?
They do make windscreen washer failed that has antifreeze in it...
Another trick if the snow is forecast is to out a tarp over the windscreen to keep the snow from melt-freezing on it.
Also Webasto is piped to the engine as Peter mentioned.
Went to all that trouble expecting to take it to south America so it was all for nothing - although the Perkins appreciates a warm start when it is frosty.
always put the poptop down if it is snowing.Peter and Sandra OKA 374 wrote: Do you sleep with the poptop down?
Every season I have thought about
Never get round to it but on balance it does not snow that often.
I am skiing at Perisher, and Thredbo Diggings is a perfect free camp only 5 mins from the ski tube which is included in my season ticket.
I also camp at a "secret" free camp close to Jindabyne below the snowline if it looks like it is going to snow. Saves putting the top down and is only half hour from the ski tube.
All of my plumbing is inside including the sink, shower, hot water service and mains pressure connection. The only exception of course is the short external connections from the two tanks to the pump. You would assume these would freeze, however they never give any trouble if I keep the hot water system and the diesel heater running.Tony Lee wrote: Almost all of my water system is inside the living area except only a short run to the shower which is well insulated with a heat strip just in case it does freeze.
Yes the Perk likes it to be preheated.
...Neighbouring campers let out lusty cheer when it finally caught after much smokey belching on one morning when I did not
Tony,
Please tell of the modifications for cold weather?....
Are you asking about mods for the engine, or the living quarters
Tony Lee wrote: One relatively easy mod to ensure easier starting in really cold conditions would be to fit a heater element in the air intake. The Perkins has a big threaded plug in the intake intended for that purpose so the element must be available.
I am aware of fuel heaters and also the manifold job.
(But where does one get the manifold heater from?)
So I was think more of the water for the living quarters. And how one keeps it from icing up?
Here in Oz it doesn't really get cold enough to freeze tanks especially if the vehicle has been driven and everything has warmed up but sitting at sub zero temps with no heating for several days will lead to things freezing well in sub zero temps.
Here in Oz the sun usually comes out at some stage to warm things up unlike overseas where temps can be sub zero for months and tanks need to be heated or be in the heated cabin and if unused need to be winterised and drained.
There was no damage but the only water we had for morning coffee was what we had in the fridge.
It thawed out by mid morning.
But we filled the jug before going to bed so had water for a cuppa and as soon as the diesel heater got going after about half an hour it thawed everything underneath with the heat from its exhaust.
Starting the 6BT was another mission as mine doesn't like cold starts at all and after a quite a few reluctant starts out west this year I've hooked the Webasto Thermotop into the heater circuit to enable engine preheating on cold mornings as well as giving us cabin heat before we drive away.
- Harry
Harry wrote: For you that own 6bt cummins with problems starting in cold climates this is what you need it is an easy fix for those that bought 6bt cummins from Paul will already have this as he bought all his engines from Canada which also have a motor warmer that warms the engine via 240 plug on the drivers side of the 6bt both these items can be bought on eBay cheers
I have only seen those in 115v in North America.
A 220v north american unit would work with 240v just dandy though.
most of the Dodge engines had heaters in the intake but most don't hook them up here in Oz.
The diesel Thermotop heats the coolant and in turn the engine up nicely to normal operating temps and I've aimed its exhaust at the sump so it will warm the oil as well. The best bit is though that the cabin heater is pushing out warm air before you even start the engine to drive off.
- Harry
This is the one that you are thinking about which goes into the side of the block on the drivers side ....
The other one which is a square one is run by 12 volt or 24 volt and is situated under the cross over pipe from the turbo to the inlet manifold
stuck back in the driveway with Kozy NP passes, free camp bookings and season ski tube and lift tickets, ....all dressed up with no where to go...
Hotham from Victoria Falls no where near as much fun as Perisher from Thredbo Diggins
Condolences, best wishes and thanks to all those doing it hard in NSW lockdown. You are doing the right thing, you WILL win, it just takes time.
- Tins
Not picking a fight, just asking. I drove bus and coach operations to Hotham and Buller, with others, for years. We were banned from using ladder style chains.
OKA #74
Hi Tins,Tins wrote: I drove bus and coach operations to Hotham and Buller, with others, for years. We were banned from using ladder style chains.
yep, you are right, this has been an understandable bone of contention for almost the 50+ yrs I have been travelling to the snowfields.
I made up the ladder set (which I prefer in mud) for the OKA out of 27m of 6mm gal chain because my diamond pattern set is too small for my 305/70 19.5's and they were too good to chop up.
