OKA Rego in WA
- FC101
Just wanting to know from someone in WA how much their OKA costs for rego per year and is it lic as a panelvan, bus,dualcab etc. on rego papers.
Thanks Gaz
- Hydramech
Cheers Kev
- FC101
Cheers Gaz
$895 for crew cab - includes insurance
One day I'm sure I'll get around to getting it reclassified.
(Peter & Paul - in Austria heading for Greece)
- FC101
Thanks Gaz
My oka cost $694.00 for the year.
- FC101
What body style is yours lic as martyn? .I see there is a bit of a price difference between the crew cab and the camper van etc. thanks for the reply.
Gaz
Mine is a camper which is easier to get approved than a motor home.
- T-Rex 146
Mine was the same as yours a panel van,
The difference with a camper and a motor home is camper has outside cooking and to go with it outside gas bottle so mine has gas bottle mounted between fuel tank and rear wheel and the cooker is in a hatch compartment above that slides out and drops down and connects via a hose to bottle so no need for venting or gas compliance tag but the compartment has to be sealed to prevent leakage to the inside, if you have 240v it will have to be tagged in my case the oka came with 240v but I disconnected when I go over pits and connect back up after and never been asked about it.
A motor home is the same as a caravan hard wired and plumbed gas and electrics with tags and suitable venting.
Both have to be set up for camping eg bed, storage,cooking yours would easily pass as a camper unless you have changed from when I last saw it.
Yes it will have to go over the pits for inspection but see your local licencing centre first as you will need paper work before inspection.
