Fuel Tanks
A standard tank is about 320 diameter x 1100 long.
- Garry and Chris
OKA 306
- Hank Onthewater
I sent them an email anyway.
hank
I've seen some travellers with the boot full of 20 litre drums of fuel and the living quarters stacked with beer, so I guess those quantities need to be added to the fixed capacities claimed.
also 30 litre grey tank for when we are camping posh, and 20 litres potable water in the calorifier. Toilet cassette that will last three days, but which is normally emptied well before that.
- Hal Harvey
We have around the same as most people seem to have, 250l water (plus 40 in the HWS), 250l fuel, 35l grey water capacity (which is not enough).Hank Onthewater wrote: Paul mentioned that the real issue for going bush and staying there for a while is not the qty of fuel, but the amount of water that can be carried. I agree.
How much should one carry? How much could one carry?
More than 1/2 a tonne of fuel and water is a lot of weight to carry, but over 120k km we've never come seriously close to running out of either.
The biggest challenges were the the Anne Beadell (only 1 reliable fuel/water stop in 1500km), GCRoad to 80 Mile Beach (2000km, adequate water but only 1 fuel stop at Kunawaritji) and Alice to PA via the Old Andado and Oodnadatta Tracks (1500km, fuel and water at Mt Dare, then Oodnadatta etc).
The most difficult areas for water are not the WA desert tracks but the north and west of South Australia which is very dry. Coober Pedy has a 20รง/20l water pump, we've been denied water at Oodnadatta, William Creek and even Blinman, and creek water (eg Algebuckina) is very salty.
Time on a track is more relevant than distance. Your fuel can easily last a couple of weeks on a slow track but not your water, so my philosophy is that fuel is more important than water. If you've got fuel you can go and find water, the opposite isn't true.
- Hank Onthewater
Or are they that good, that they are able to qualify a genuine prospective client....? And considered my enquiry as not?
Indeed, I might shelve the idea of replacing the fueltanks for the moment. No one seems interested in buying my current tanks. Mick who also wanted a set of tanks, is now selling his #236, and I am thinking of buying a nautical toy. And most importantly I am not considering long distance trips over the next 12 months.
But the issue of tankage remains valid: how much is enough and how much is too much. And just now David put another slant on it:
How much to you carry David?If you've got fuel you can go and find water, the opposite isn't true.
hank
We check the levels regularly, especially before setting out on a long track, to ensure the gauges aren't lying to us.
Alister
Cheers, Alister
- Hank Onthewater
Sorry, as my plans for making these tanks have been delayed, I can't offer you detailed drawings or photos.
I was not planning to use the existing brackets, although the plan was to use the holes at the rear of each tank for the new brackets, and add another attachment point (by welding) as the new tank are twice the weight (when filled). As my tanks would be longer, I could not re-use the holes of the front of each tank, and therefore new attachments needs to be welded to the frame.
But if you or others have brilliant ideas, I am happy to copy them!.
hank
- Hank Onthewater
With some rounding, some 'indentations' I expect it can hold around 250 lt.
The other side is to follow after the first one is in place. That tank will be the same size initially, but steps etc will reduce the content to approx 200 lt.
The tanks will be supported by 3 brackets each, and have 2 baffles each.
The batteries have to be relocated.
Both tanks will be well inside the busbody, so I can mount/hang some sand tracks/ladders both sides, and they won't stick out.
After travelling all over Oz in the last 35 odd years, over all the iconic outback routes plus a few that are not usually attempted, mostly in Troopies with two 90L tanks I wonder why people see the need to carry such huge amounts of fuel. A fuel capacity of 250 litres in an Oka sized vehicle is more than adequate for everything except say a Madigan crossing of the northern Simpson where there is a set distance to cover over remote country in soft sandy conditions where fuel usage will be extra high and no refuelling is possible enroute. On these rare occasions carrying an additional jerrycan or fuel bladder is far easier and cheaper than the cost of making and fitting extra tanks.
The argument for carrying huge amounts from cheaper sources into remote areas is negated by the increased wear and tear on the vehicle, tyres and possibly increased consumption due to road conditions etc. Never mind the cost of so called long range tanks and the suspension work needed to carry the additional load.
Most 4wd's set up for long distance work would be over GVM and given that the same amount of gear is carried regardless of vehicle an Oka sized vehicle should be able to travel at a weight less than or close to GVM. Although looking around there are plenty that are well over GVM
- Hank Onthewater
- Hank Onthewater
- TH
Cheers, Tony
Make sure you baffle them well, I'd reckon at least two in that length, just make them full size and cut the corners off about 30mm triangles. Otherwise they might fatigue due to the fuel washing up and down inside and ally doesn't flex well long term.
- Hank Onthewater
Of course there are additives for sale that prevent algae growth, removes water or separates the water from the fuel. And I know of at least one home made concoction: with every tank fill, add some naphthalene shavings. Not sure if it works though.
Better still is to prevent water coming in. One way this water can enter the system is when tanks are not full: the daily contraction/expansion of air introduces air into the tank when it cools; and when it cools further, condensation is formed. There are filters that one can buy to be fitted into the air-vent hose.
Here is a test of some of those filters. Although the article is aimed at yacht owners, it applies to any kind of (diesel) fueltanks. This link will only be valid for a few months before the article is archived. Then you have to subscribe to Practical Sailor to gain access to this.
- Hank Onthewater
