Australian maps 'forgotten'.
20 May 2014 09:08 #1
by Paul Scherek
Paul Scherek created the topic: Australian maps 'forgotten'.
I am receiving the following message when I try to look at the maps in the Documents and Data section. Not sure if this is down to my computer or if it is a site thing.
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 23684 bytes) in /var/www/vhosts/oka4wd.com/httpdocs/plugins/content/jw_simpleImageGallery/jw_simpleImageGallery/includes/helper.php on line 105
20 May 2014 09:30 #2
by Tony Lee
Tony Lee replied the topic: Australian maps 'forgotten'.
Same here. Solution is simple - a Bex powder, a good lie-down in a darkened room and try again tomorrow.
20 May 2014 09:34 #3
by PeteFox
PeteFox replied the topic: Australian maps 'forgotten'.
This is a stack overflow error in the php.ini file. It just means that the memory limit in the settings for the file is too small for the script that is to be executed. It is simple to fix but here are penalties with server loading and speed. It is not your computer.
A job for James
A job for James
20 May 2014 13:35 - 20 May 2014 15:50 #4
dandjcr replied the topic: Australian maps 'forgotten'.
Paul, you are not alone, I get that too, and I posted the maps!
I'll investigate or ask James to check it out.
Edit. Can't see anything amiss with the files in the back end. Other areas I tried seem to be working OK.
Yes, what Pete says, a James task.
Last Edit: 20 May 2014 15:50 by dandjcr.
20 May 2014 15:47 #5
by Paul Scherek
Paul Scherek replied the topic: Australian maps 'forgotten'.
Thanks gents, I will try again in a couple of days.
- Chrisj
21 May 2014 05:04 #6
by Chrisj
Chaos, Panic, Disorder - My work is done here.
Chrisj replied the topic: Australian maps 'forgotten'.
Chances are that a recent upgrade in the Joomla backend hasn’t installed properly or is not compatible with the version, the answer is given the error code, /plugins/content/jw_simpleImageGallery/jw_simpleImageGallery/includes/helper.php on line 105
regards, Chris.
regards, Chris.
