adaptor l480e auto box to np205transfer case
17 Nov 2014 10:00 #1 by arcs01
arcs01 created the topic: adaptor l480e auto box to np205transfer case
Hi Guys anybody know where i can get adaptor housing or plate to suit L480e gearbox to np205 trans case
17 Nov 2014 10:26 #2 by Outback Jack
Outback Jack replied the topic: adaptor l480e auto box to np205transfer case
There are several places
Nth West Fab
Advance Adapters
Trail Tech See Same.
Trail Tech Mike
Mike is a great guy and easy to do deal with. His kits are great.
17 Nov 2014 11:05 #3 by arcs01
arcs01 replied the topic: adaptor l480e auto box to np205transfer case
Hi thanks would you have his contact details please
Thanks Alistair
17 Nov 2014 12:48 #4 by Outback Jack
Contact info
Mike
Trail Tech Fab
860-341-1883
The following user(s) said Thank You: outyonda
17 Nov 2014 15:44 #5 by OKABloke
OKABloke replied the topic: adaptor l480e auto box to np205transfer case
Why a 4l8e and not a 6 Speed Alison with Patrol Transfer Case. Should be similar money
17 Nov 2014 19:58 #6 by Outback Jack
and Mike does an adapter for both......
18 Nov 2014 19:09 #7 by Alister McBride
Alister McBride replied the topic: adaptor l480e auto box to np205transfer case
What's the length difference between an Allison/Nissan setup versus the 4l80e/NP205? I've been searching a bit but can't find much, does anybody know? Dave could you possibly measure from start of bellhousing (rear mounting face of engine) to mounting surface for rear yoke? And can someone do the same for the 4l80e/NP205 setup?
Both would be great to know so we can make a decently informed decision...!
Cheers, Alister
The following user(s) said Thank You: TH
19 Nov 2014 10:33 #8 by Garry and Chris
Garry and Chris replied the topic: adaptor l480e auto box to np205transfer case
Spare electronics for Alison very expensive Alison guy talked me out of it
OKA 306
19 Nov 2014 11:27 - 19 Nov 2014 11:28 #9 by outyonda
outyonda replied the topic: adaptor l480e auto box to np205transfer case
Allison bits availability, stronger as standard model,buy with electronics & shifter, cheaper overall
same with H/D NP205 Both Bullet proof.[well nearly bullet proof]
Last Edit: 19 Nov 2014 11:28 by outyonda.
20 Nov 2014 07:49 #10 by Alister McBride
Anybody able to post the lengths of each setup, as in what i posted above?
Cheers, Alister
  • Peter and Sandra OKA 374
20 Nov 2014 10:09 - 20 Nov 2014 10:14 #11 by Peter and Sandra OKA 374
Peter and Sandra OKA 374 replied the topic: adaptor l480e auto box to np205transfer case
Alister here is the measurements from 374, within a couple of mm as I just did it with a tape measure under the truck.
Anyone has any questions fire away
Perky/industrial flywheel housing/housing to chev pattern adapter/4L80E auto/Marks adapters adapter without clocking ring/Nissan GU transfer/rear tailshaft
Last Edit: 20 Nov 2014 10:14 by Peter and Sandra OKA 374. Reason: addendum
The following user(s) said Thank You: Alister McBride, Joseph Baz
20 Nov 2014 10:39 #12 by OKABloke
From the back of the motor to the back of the Handbrake 1200mm
Allison, Adapter Plate, Nissan Patrol Transfer Case.
21 Nov 2014 07:33 - 21 Nov 2014 07:50 #13 by outyonda
Will start A NEW TOPIC
Expression of interest??
I have some 6bt Cummins on A boat & have Allison 2000. HD/Np205 & adapters to come!!
Mike's are 6 bolt, OKA is 8 bolt but a few mod's tail shaft clearance issues to be sorted.
Last Edit: 21 Nov 2014 07:50 by outyonda.
21 Nov 2014 07:44 #14 by Alister McBride
Ripper guys, thanks for that! I measured the standard setup to roughly 1230mm from the front of the engine/bellhousing adapter plate to rear yoke mounting surface.
This means that the Allison/Nissan setup is similar in length to the standard setup, so did you extend your chassis for the camper setup Dave, not to accommodate the new drivetrain?
Peter, i thought the rear driveshaft was already quite short but obviously you guys have no troubles with it being roughly 200mm shorter?! Have you tilted the drivetrain/diffs to reduce the angle on the U-Joints?
Thanks to both, that's exactly what i and probably a lot of others wanted...
Cheers, alister
21 Nov 2014 07:55 #15 by OKABloke
We extended the chassis 200mm to accommodate the Allison prior to knowing the length. We have also set up our Engine and Trans up high for extra ground clearance
21 Nov 2014 09:48 #16 by Peter and Sandra OKA 374
The Perky is just slightly more nose up, occasionally in low range the fan touches the top of the shroud.
As quite a few Oka's have had done I fitted 16mm tapered shims under the spring perches to rotate the diff nose up slightly to about where it should be as in standard form the diff nose points down which is why Oka's have a reputation of chopping out uni joints. This gives a good line for the rear tailshaft and doesn't affect the front one.
The tailshafts are standard GU Nissan with Oka compatible outer ends.
As I said in the earlier post the Marks Nissan transfer adapter for Oka's includes a clocking ring which I didn't use as it is designed for a Chev V8 install and the transfer case would be further forward which could cause clearance issues between the front tailshaft and the transmission pan, with the Perkins that doesn't happen as the industrial flywheel housing moves the transmission 155mm rearward.
21 Nov 2014 18:08 #17 by DarrenWebster303
DarrenWebster303 replied the topic: adaptor l480e auto box to np205transfer case
Alister, I cut the rear spring saddles off & rotated the pinion up to point at the back of the transfer case. A double cardan joint on the front of the shaft & it is as smooth as silk. I also cut a rectangle out of the rear diff cover & welded it back in upside down to raise the fill level so the pinion bearings don't hate me.
The following user(s) said Thank You: Russ Phelan
21 Nov 2014 18:14 #18 by DarrenWebster303
Oh & yes we straightened the rear tubes after cutting & welding the saddles.
21 Nov 2014 19:16 #19 by Russ Phelan
Russ Phelan replied the topic: adaptor l480e auto box to np205transfer case
This is all awesomely good info for the evolution of the OKA.
Instgram @okaruss #okatruck
21 Nov 2014 19:18 #20 by Russ Phelan
DarrenWebster303 wrote: Alister, I cut the rear spring saddles off & rotated the pinion up to point at the back of the transfer case. A double cardan joint on the front of the shaft & it is as smooth as silk. I also cut a rectangle out of the rear diff cover & welded it back in upside down to raise the fill level so the pinion bearings don't hate me.
More oil to the wheel bearing as well???
