Fuel Tank side mounting Brackets
24 Feb 2015 14:25 - 24 Feb 2015 14:27 #1 by Outback Jack
Outback Jack created the topic: Fuel Tank side mounting Brackets
Has anyone got sitting around fuel tank side mounting brackets to suit a Bus with steps????
They are different to standard mounting brackets and are in by about 15 to 20 mm.
If you don't have steps on a bus body, then they are not needed..... But only way to fit steps is with these mounting brackets, making the tank sit closer to the chassis.
Last Edit: 24 Feb 2015 14:27 by Outback Jack.
26 Mar 2015 16:29 #2 by Outback Jack
Outback Jack replied the topic: Fuel Tank side mounting Brackets
Just thought I would put this back out there.
Al doesnt have any, not sure if he even has the drawings.
But need LH Fuel Tank Mounting Brackets.
Any one have them hidden in a shed somewhere..............
Or if your doing a rebuild and have them off at the moment? Maybe I can get an engineering shop to copy them
26 Mar 2015 19:30 #3 by Alister McBride
Alister McBride replied the topic: Fuel Tank side mounting Brackets
Try Pete Furlong or Ian Jones (he's probably used my old set already from a few years back but he may have some lying around. I doubt he gets on here so wouldn't respond...)
Cheers, alister
