Front axle housing WANTED and other front end bits.
26 Oct 2018 16:43 #1 by Peter_n_Margaret
Peter_n_Margaret created the topic: Front axle housing WANTED and other front end bits.
Front axle housing wanted - with or without crown wheel & Pinion, axle shafts, etc.
Wheel to wheel would be considered.
Must be straight and in good condition.
Also wanted steering rods & steering knuckles.
PM or call 0428 171214
26 Oct 2018 17:33 #2 by Paul Scherek
Paul Scherek replied the topic: Front axle housing WANTED and other front end bits.
That sounds ominous Peter - hope you haven't had a disaster.
Have you tried Paul Knott?
26 Oct 2018 18:03 #3 by outyonda
outyonda replied the topic: Front axle housing WANTED and other front end bits.
OKA parts, chesk out Joe Baz photo in spotted an OKA
26 Oct 2018 18:08 - 26 Oct 2018 18:12 #4 by Peter_n_Margaret
Peter_n_Margaret replied the topic: Front axle housing WANTED and other front end bits.
Paul Scherek wrote: That sounds ominous Peter - hope you haven't had a disaster.
Yes, talking to Paul and Dean. There are options available.
#196 took off down a hill with no one on board. Lots of front end damage, but no one hurt thank goodness.
Last Edit: 26 Oct 2018 18:12 by Peter_n_Margaret.
26 Oct 2018 18:30 #5 by Ewart and Vivian Halford
Ewart and Vivian Halford replied the topic: Front axle housing WANTED and other front end bits.
Oops, sorry to hear that Peter.
26 Oct 2018 20:32 - 26 Oct 2018 20:35 #6 by Holmz
Holmz replied the topic: Front axle housing WANTED and other front end bits.
Peter_n_Margaret wrote: Front axle housing wanted - with or without crown wheel & Pinion, axle shafts, etc.
Mine is due any day from the shop in 4.88:1 (dropped of three weeks ago)
It is easier to ship and not install,,,
It has a new Trutrack, new pinion and carrier bearings, seals, etc, etc, etc,
PM me if interested... otherwise I will install it when it is ready! (Which should be any day now)
Last Edit: 26 Oct 2018 20:35 by Holmz.
27 Oct 2018 04:47 #7 by Paul Scherek
Peter_n_Margaret wrote: #196 took off down a hill with no one on board. Lots of front end damage, but no one hurt thank goodness.
Oh, bad luck, Peter, hope you can be back on the road soon.
27 Oct 2018 05:36 #8 by Holmz
That reminds me that my parking brake is not working too flash...
27 Oct 2018 06:49 #9 by Peter_n_Margaret
Mine works OK if I apply it properly …..
28 Nov 2018 15:21 #10 by Peter_n_Margaret
BUMP.
Still looking for an XT (not interested in LT) front diff housing.
Bare preferred, but consider an assembly.
28 Nov 2018 17:20 #11 by Ralley
Ralley replied the topic: Front axle housing WANTED and other front end bits.
I have one. It was replaced with a heavy Dana 70. The short side has a little bit of negative camber. It had an adjustable lower king pin fitted.
28 Nov 2018 18:37 #12 by Alister McBride
Alister McBride replied the topic: Front axle housing WANTED and other front end bits.
I rang and offered you one, you said you had one...!
28 Nov 2018 19:30 #13 by Peter_n_Margaret
Sorry Alister, I thought I had one, but when it arrived it was an LT not an XT and I don't want to go there and I could not trace your number. Please try again. :)
Ralley, please PM details.
I will be fitting new HD knuckles, spindles and callipers and I have 35 spline axles free wheel hubs and diff centre.
29 Nov 2018 21:44 #14 by Holmz
Did you end up changing the P-brake?
30 Nov 2018 06:09 #15 by Peter_n_Margaret
No, not yet. The existing one works if I apply it properly, but Pauls disc would be an a attractive upgrade.
