Waste gate turbo for Standard Perkins 4cyl
31 May 2020 16:12 #1 by Carl B
Carl B created the topic: Waste gate turbo for Standard Perkins 4cyl
I have been reading all I can on here about turbo options for the standard Perkins and spoken with Martin a couple of times about his turbo. Whilst I'd like a new one it seems Martins next order might be some time give the situation with china/covid19, freight etc. I'm also toying with getting a Garrett WG one for a 135ti and adapting if required etc. I did however have the thought that some of you may have a waste gate turbo sitting in your shed for the standard Perkins 110t that you'd like to part with? Maybe you've put a larger engine in and have either Martins turbo or another type you fitted to the old Perkins some time ago? Just seeing what's about while I have time to fit. Any advise/experience/thoughts are most welcome from those of you that have fitted alternative turbos to the standard Perkins.
31 May 2020 20:35 #2 by Peter_n_Margaret
Peter_n_Margaret replied the topic: Waste gate turbo for Standard Perkins 4cyl
#196 uses a Garret T2554 wastegated turbo.
03 Jun 2020 16:33 #3 by Carl B
Carl B replied the topic: Waste gate turbo for Standard Perkins 4cyl
Hi Peter, Thanks for your post. I've just bought one of Martins "swift" turbos. Was a new one not being used/kept as a spare so got lucky there. Should be here to fit over the weekend. Looking forward to seeing what sort of difference it makes.
04 Jun 2020 04:36 #4 by 210greg
210greg replied the topic: Waste gate turbo for Standard Perkins 4cyl
210 went from 55hp to 94hp 366 ended up 104 hp very different truck
