112 update
01 Nov 2012 15:14 #1 by dandjcr
dandjcr created the topic: 112 update
Forum Home > On the Road > 112 update
112 is well on its way to being finished. Chassis, diffs, motor, tanks, the lot is back together, all new bushes, bearings etc through out including the diffs.
Cab - currently working on the cab change over from the XT to the LT. this has turned out to be quite an ordeal. Everything needs to be refab'd to fit. Everything.
AC- Redot roof type. This requires the unit to be flat when installed. at this stage im going to rase the roof to equal the rear height, this way the AC will lay flat. lots of work but will increase the front headroom which we can use for storage or radios etc.
Electrical - was going to re-use some of the wiring harness to save a bit of time and money. I pulled it apart today and found many many crimp joins within the harness. Wires from the first fuses were crimped about 100mm inside the harness. The joins are from the factory. I'm suprised they don't burn out at the hot spots? or do they... removed the full harness and threw it away to start new.
All for now
happy trails
cando
Happy trails
Cando and Bron XLT 112
April 16, 2011 at 6:37 PM Flag Quote & Reply
James & Usha (THEByleDuct)
Wiring is one of the things I want to go through and totally redo as well. I'll be interested to hear how you get on with it.
James
OKA #072
April 16, 2011 at 7:16 PM Flag Quote & Reply
Posts: 199 James, are you having wIring issues now? I'm interested to see the cost
Happy trails
April 17, 2011 at 6:02 PM Flag Quote & Reply
No wiring 'issues' as such. When we were coming across the Barkley the front aircon fan died. Whilst searching through the wiring to find the problem it struck me that the wiring needed an upgrade. Too many unnecessary joins, too many wires, too many possible fire hazards. I'm a bit of a stickler for wiring and so it is high on my list of upgrades.
OKA #072
April 17, 2011 at 8:31 PM Flag Quote & Reply
Also no cost yet because all our money is going into the nephews surgery at the moment. Need to sell more gear.
OKA #072
April 17, 2011 at 8:56 PM Flag Quote & Reply
James, did you get me message re the price of your PTO and winch?
Happy trails
April 19, 2011 at 5:06 PM Flag Quote & Reply
Well we cut the cab roof off today and made a flat one. Lifted front by 40 and dropped the rear by 60mm. looks OK. I was wanting to remove the existing 2 piece roof to avoid any probs later, so why not go the hole hog.
I'd put a pic here but I cant work out how?? Look in my pic file and you'll see the changes so far.
Happy trails
April 19, 2011 at 5:49 PM Flag Quote & Reply
Photos below
OKA #072
April 19, 2011 at 6:18 PM Flag Quote & Reply
thanks James,
Happy trails
April 19, 2011 at 6:29 PM Flag Quote & Reply
Any more updates?
July 9, 2012 at 3:58 PM
