- 2012 Maintenance Archives
- April 2012
- Resealing a Leaking Injector Pump
31 Oct 2012 19:48 #1
dandjcr created the topic: Resealing a Leaking Injector Pump
Forum Home > OKA Maintenance > Resealing a Leaking Injector Pump
The injector pump on our Oka developed an annoying minor leak from the rear distributor head several years ago but recently it suddenly got a lot worse so I took the pump off to fix it.
It was not a quick or easy job and I've written up some notes on our blog here in case anyone needs to do something similar, or you can download a pdf of the same information from the Contributions category of the Documents and Data section here.
April 8, 2012 at 1:56 PM Flag Quote & Reply
David i to had to remove the injector pump as well and found it was a night mare to get to the bottom bolt above the hyd pump , i replaced mine as it was for a staitionary motor , only to remove it again to replace the keyway that had sheared off so i also had some fun,but now i know it wont be so dauting job cheers peter
April 8, 2012 at 7:20 PM Flag Quote & Reply
Peter, yes the lower flange bolt is a bugga and I didn't anticipate having to remove the hydraulic pump and oil filter/cooler to gain access to it.
Maybe there's a better way but I couldn't find one.
April 9, 2012 at 7:50 AM Flag Quote & Reply
David to get to that nut as i can remember i used 1/4 " socket with a few exstesions on and it was still hard ,i have replaced the oil filter and tank to a new spot and that isnt in the way anymore ,i looked at removing the hyd pump, and that would be the same as , still hard cheers peter
April 9, 2012 at 6:50 PM
