speedo
31 Oct 2012 19:50 #1 by dandjcr
dandjcr created the topic: speedo
Forum Home > OKA Maintenance > speedo
Greg #210 and Dean #366
Thanks for the replies 210 has second gauge behind passenger seat both stopped so I think not mechanical PS I cant seem to add post to old topics?
April 6, 2012 at 5:09 PM Flag Quote & Reply
Greg as far as I know (mine's an XT) , the odometer is an electro mechanical device which works off the same electical inputs from the sensor as the speedo, so if the speedo is working it must be an odometer fault.
Don't know what your second gauge might be. Is the LT diferent to the XT?
April 6, 2012 at 6:01 PM Flag Quote & Reply
Is the one behind the passengers seat a Tachograph? could be if it was a bus used commercially. They will both use the output of the speed sensor located on the rear of the transfer case so if both ahve dies I'd look at it from the transfer case connections first.
April 6, 2012 at 9:26 PM
