Rims, 16" Steel Tubeless
31 Oct 2012 19:36 #1 by dandjcr
dandjcr created the topic: Rims, 16" Steel Tubeless
Forum Home > OKA Maintenance > Rims, 16" Steel Tubeless
outyonda.com
I have the first ten rims manufactured, powder coated & tyres fitted, balanced & on the OKAs. Rims will be available through Alan at OKA Parts Australia 0400 736 117, for info Brett 0429 831 040 Extra Tuff OKA rims. We require your centre dish, take the rim to a machinist to turn the outer rim off. A professional rim manufacture, double welds & powder coats, tour collor. Extra Tuff OKA rim 8x16 $350 exchange 10x16 $400 exchange Tuff OKA rim. we can make pressed centres. 8x16 $450 10x16 $500 there is ten rims in the pipeline at the moment. cheers Brett
April 18, 2012 at 10:02 PM Flag Quote & Reply
Hi Brett,can you tell me what the loading rate of these rims and are these certified for road use or only off road.
cheers,Joe
May 2, 2012 at 11:57 AM Flag Quote & Reply
outyonda.com
G,Day Joseph. The rims are manufactured by a licensed rim maker. He re made, balanced & centred many of the original OKA wheels. To answer the question, yes suitable for road use. Alan has one at Oka Parts Aus. As for load rating, the original split rim centre with extra thick/strong rim double welded, I would say better than two tonnes per rim. We can make centres but not as strong. Also 19.5 rims cheers Brett
May 2, 2012 at 10:26 PM
