Cab removal
01 Nov 2012 12:03 #1
dandjcr created the topic: Cab removal
Forum Home > OKA Maintenance > Cab removal
Has any one had to remove the cab from an OKA? We need to remove to repair rust in front underside, both sides etc. Can the cab be removed with the dash in place? any and all help would be great as this is the first step in refurbing the old girl.
Happy trails
Cando and Bron XLT 112
August 3, 2010 at 7:05 PM Flag Quote & Reply
Cab can be removed as a complete item,very heavy thou,you have to do a lot of disconecting before lifting,eg,brake lines,clutch hyd lines,power steering lines,electrical wiring,gear linkages,air cleaner hose,etc,etc,if I remember correctly it should be a procedure section in the repair manual.hope this may help
August 3, 2010 at 8:58 PM
Happy trails
