rear brake prop valve diff bracket
01 Nov 2012 11:16 #1 by dandjcr
dandjcr created the topic: rear brake prop valve diff bracket
Forum Home > OKA Maintenance > rear brake prop valve diff bracket
Can any help me as i am replacing the prop valve at the rear of my oka ,it has no bracket to be able to connect the adjustment chain to , i need to know the measurements ,centre of hole long side to fold,centre of hole short side to fold ,width of flat from fold to fold the rest i will work out thanks peter 334
December 15, 2010 at 8:22 PM Flag Quote & Reply
I'll make a point of going up the shed and measuring it for you this morning.
December 16, 2010 at 6:09 AM Flag Quote & Reply
I've taken a couple of pics and also made a rough diagram which should have the measurements you want.
Mine doesn't have a chain, instead a short cable so don't know if the bracket is the same.
December 16, 2010 at 10:02 AM Flag Quote & Reply
Peter & Sandra James Oka 374 at December 16, 2010 at 6:09 AM
Peter & Sandra , Thank you very much for your help ,now i am able to start to repair the brake system , very much appreciated . peter334
December 16, 2010 at 7:56 PM
