Six cylender perkins conversion
- OkaDaz
06 Jul 2015 19:37 #1
by OkaDaz
OkaDaz created the topic: Six cylender perkins conversion
OKA Darren Visser has successfully completed a six cylinder phaser conversion to a LT OKA BUS coupled to the standered spicer transmission and has a spare six cylinder 160 HP phaser and is offering that engine supplied and fitted to a LT OKA including upgraded radiator and accessories for $25,000 to be fitted in Melbourne with roughly a three week turn around.Drive in drive out.It could also be done to a XT OKA.
Must ring on 0419 522 225 as I do not go on the computer much.
Darren Visser
Darren Visser
- OKAFELLA
07 Jul 2015 12:00 #2
by OKAFELLA
OKAFELLA replied the topic: Six cylender perkins conversion
Bloke in Hern Hill W A put a 160 Phaser in a OKA,
Front axèl hits sump, ?
07 Jul 2015 18:15 - 07 Jul 2015 19:34 #3
by Outback Jack
Outback Jack replied the topic: Six cylender perkins conversion
Hey OKAFELLA, want to let us know more about you? Do you own an OKA if so what is its number? Or do you have a repair business?
A bit of an intro would be great.
Last Edit: 07 Jul 2015 19:34 by Outback Jack.
09 Jul 2015 07:55 #4
by outyonda
outyonda replied the topic: Six cylender perkins conversion
the reason OKA did not use the 6 cyl perk s it's too heavy.
I have seen the cracked sump!!, not the axle, the webbing on front diff hits.
09 Jul 2015 14:20 #5
by PeteFox
PeteFox replied the topic: Six cylender perkins conversion
Perkins 1006T-6T dry weight 422kg - source Perkins brochure
Cummins 6BT 12V 498kg - source Cummins Hub - cumminshub.com/12v.html
Sump? its a matter of getting the right one, the Cummins one will hit too if it is the wrong one fitted.
- Paul
09 Jul 2015 15:06 #6
by Paul
98OK
A0
Paul replied the topic: Six cylender perkins conversion
180 I think it is fits f all room to play under cover weight on bridge ok ,
98OK
A0
- Peter334
14 Jul 2015 16:10 #7
by Peter334
Peter334 replied the topic: Six cylender perkins conversion
Got a cummins in ours and it fits like a glove and it goes very well with auto no more stupid 5 speed gearbox have done 2 weeks of sand dunes and the auto thought for its self no getting the wrong gear
The following user(s) said Thank You: OKAPETE, Joseph Baz, Stephen Knowles, DarrenWebster303
