XT emergency parts list
- packhorse
- Paul
98OK
A0
packhorse wrote: Call me lazy but does anyone have a list of the important bits to travel with beyond the Telstra line, eg, radiator hoses, uni's, etc. I need to get a quick kit together of these necessities and their easy to gather part numbers for here on the West side. This would be greatly appreciated and also an insight.
Mick the flippant answer would be "depends on what you're going to break".
A more considered response would be: don't worry too much about spares (since you don't know what you're likely to need), but fill a box with simple things, like sticky tape, bit's of metal and rubber, fencing wire, galvanised cable (clutch cable fix), tubing/hose of various sizes, tent pegs, M6, M8 nuts and bolts, Tek Screws and hand tools. Then you can use your inner bush mechanic to fix most things.
Know where the injector pump solenoid wire is, as that's the only electrical item which can prevent the engine from running, and take some electrical wire/tools to fix it (ie connect it to +12v).
I see from your previous posts that you've done a fair bit of maintenance/repair already so you're beginning to find you way around your Oka. If there are no major leaks and nothing seems to rattle or move when it shouldn't, your Oka will probably prove quite reliable. Minor leaks and rattles are normal and annoying rather than worrying.
What you should take is 2 spares wheels, wheel brace, preferably 2 heavy duty jacks, a tyre plug repair kit, a compressor, plus some engine, gearbox, diff and hydraulic oil. 2 working batteries are a good safety net too. Same with a spouse for sage advice, holding things and ability to push. And if you're really going where Telstra's sun don't shine, consider a Sat phone or EPIRB for emergencies.
Pretty much anything else is a nice to have. We've carried tonnes of spares around the country for years and hardly used any of them.
BTW, you can bump start an Oka fairly easily on hard ground (not sand) in the event of starter failure (don't ask how I know).
Regards, David
- packhorse
packhorse wrote: Cheers, got all those things, whiskey too. Will track down belts & hoses and get going. I'll be back.
Mick, the only hoses we've ever broken/leaked are the small ones around the oil cooler. I got a Holden hose from Supercrap with all the necessary bends and cut it up to suit.
Belts can break but sometimes a branch flicks up underneath, gets caught in the belt and flips it off the pulleys. Strapping a spare main belt to the engine block behind the pulleys makes replacing it easier than removing all the other(s) first.
