Bosch EPVE injector pump
- The awesome
01 Jul 2017 14:11 #1
by The awesome
The awesome created the topic: Bosch EPVE injector pump
I need to remove Bosch EPVE injector pump so I can replace broken inner stud. I would appreciate feedback from anyone that has done that procedure,advice as what special tools are needed ,things to watch out for,and sequence of the job involved.
Thank you . Jim
Thank you . Jim
01 Jul 2017 15:12 - 01 Jul 2017 15:22 #2
dandjcr replied the topic: Bosch EPVE injector pump
Jim, I've done this a few times and there a few gottcha's, plus it takes a fair bit of time, care and patience.
I suggest you read my notes in this document and I or others can fill in any blanks later.
If you need to do anything internal, I would suggest taking it to a specialist as they are complex devices and any mistakes can wreck the pump. Although I successfully fixed mine a couple of times, eventually I had to have the whole thing overhauled as other wear problems showed up. Cost a small fortune but certainly improved the performance. Plus it's a critical single point of failure.
Last Edit: 01 Jul 2017 15:22 by dandjcr.
The following user(s) said Thank You: The awesome
- The awesome
01 Jul 2017 20:26 #3
by The awesome
The awesome replied the topic: Bosch EPVE injector pump
Thank you very much! This info is going be invaluable, I will read it a few times before I commence the job.
